Versa battery is lasting too short
How long is the battery suppose to last after a full charge, I’m charging mine every other day,,i thought it would last longer than that
15 REPLIES 15
Hey @RossJ, it is great to see you around more often! The Fitbit Versa battery can last up to 4+ days. Because battery life is affected by use and other settings, actual results may vary.
Consider these tips when you want to conserve battery life:
  • Make sure you're charging Versa fully each time. It can take up to 2 hours to charge your watch. For instructions, see How do I charge my Fitbit device?
  • Turn off the option to wake the screen when you turn your wrist; instead, tap the screen to turn it on:
    • On your watch, press and hold the back button, then swipe to the quick settings screen > Screen Wake > Manual.
  • If you don't need heart rate data, change the Heart Rate setting to Off. Note that the green LED continues to flash even if Heart Rate is turned off.
  • Turn off call, text, calendar, and app notifications if you know you're going to receive many hundreds of notifications. A large volume reduces battery life:
    • On your watch, press and hold the back button, then swipe to the quick settings screen > Notifications > Off.
  • Charge your watch more often if:
    • You play music or use the music controls frequently
    • You use apps that keep the watch's screen on or frequently access the internet
    • You use an interactive or animated clock face
  • Don't receive reminders to move every hour. To get fewer reminders, make sure you walk 250 steps each hour, change the number of hours you want your stationary time monitored, or turn off the feature on days you don't need it.
  • If you have many silent alarms set, consider deleting some. Each alarm you add up to the maximum of 8 reduces battery life by a small percentage.
  • Shut down Versa when it's not in use. For instructions, see How do I turn off my Fitbit device?
Let me know how it goes!
Heydy | Community Moderator, Fitbit
Well Fitbit don’t tell you all that before you buy,,,no mention if you don’t use this or that,,just says the battery will last a few days can’t remember the actual days..just saying that for people to buy them,then they tell you well if you don’t use it for what I bought it for the battery won’t last long..typical marketing scam..no need to reply cause you get paid by Fitbit and you say that they tell you to say.
Hello. I have had the Versa for about 11 months. I had many of the options turned on, such as the heart rate monitoring, which was one of the prime reasons I purchased the Versa. I would say that up until about 3 weeks ago, I was charging it maybe once every three days. I was fine with that. Lately I get maybe a day out of it before the battery is close to dead. I am very disappointed with the watch. Having to turn all these options off to get more than a day out of it seems like a weak solution to me especially since the heart rate monitoring was the primary reason for purchasing it.
I’m having the same issue and plan on calling tech support.
What do you do when it won't charge at all? I've owned mine 9 months
You will have to replace it.  If you've only had it for 9 months, you are still under warranty.  Reach out to the Fitbit team for assistance.  They replaced mine when it stopped charging.
Mine is still charging but the battery drains fast,
Same here! i love the Fitbit, but its seems like a "single use smartwatch". 😞 I dont lisen to the music on it or anything else that can drain the battery off. Simply for clock and sleep tracking. recenlty went from 12h to..barely 6h/day if not even less.
its supposed to last 4+ days
this doesnt work, sorry. Please fix this fitbit issue. its not a cheap watch. my 7 year old son has a 10$ clock on amazon and the battery last foreverrr and its been more than 1 year
For a $200 watch, the Fitbit Versa battery issue is an accident waiting to happen to the Fitbit franchise when it comes to exercise equipment. I can see why the company jumped at the chance to become a part of the Google conglomerate because, like most disappointed users, I will never buy another one.
I feel the same way. I brought an Apple Watch recently.
Mine has the warranty on it and I've sent it in 3 or 4 times now in the last few months. The battery being the last time I sent it in. The battery on the original watch I had wasn't even an issue but the replacement watches drain so quickly. I read if you only install fitbit apps and watch face it fixes the issue since I don't listen to music and I don't have a lot of notifications coming through. That was WRONG! I have to charge it DAILY! I use to be a true fitbit fan before all of these issues. I'm almost ready to look for other options.
Thanks for the suggestions, I think.
This is a fairly long post and will likely take some time to respond to it appropriately.  For this reason, I have provided a summary at the beginning rather the end.
TL;DR: (1) Re: battery life. This is not an isolated issue. WTF? More importantly, what is Fitbit doing about this? (2) Long term solution: is it time to jump ship and get an Apple Watch?  I’ve been loyal to Fitbit for 6+ years. Please convince me to stay with Fitbit.
Full letter:
I agree that many of the “battery saving” tricks you suggested are precisely the features why we bought it in the first place.
It is promoted as a fitness watch that can do a number of important things and still last 4+ days.  These features include:
Critically important for many users:
• monitor HR (most people who use this either assume or need this feature always on).
• monitor a full night of sleep (this is one of my favorite features)
• count steps (it’s original raison d’etre).
• count flights of steps
• provide the time when lifting arm to view watch-face.
As tech has evolved and improved, Fitbit has released new devices regularly. One of the distinctions of Fitbit has always been its outstanding battery life, especially compared to smart watches like the Apple Watch.  As Fitbit has released new devices, it has advertised additional features along with long battery life.  Some of these newer features (and useful original features) include:
• effective silent alarm (again, one of my favorites and something I rely on every day).
• reminders to move periodically if the wearer has been too sedentary. This, and similar reminders (to wash hands, etc) are directly relevant to Fitbit’s stated mission.
• ability to estimate O2 blood saturation and variability, especially overnight. (Another aspect that helps Fitbit rise to the top of sleep trackers.)
• swim tracking (in a pool)
• ability to guide wearers as to how much time spent in “the zone” (honestly, this is frustrating for me because my resting HR is a little fast and the customization instructions are confusing and inconsistent).  I frequently “max out” my weekly 150 minutes without any intentional exercise. Unfortunately, I don’t know how to turn this feature off and keep O2 monitoring.
Fitbit advertised that the wearer could get all of these features and still have good battery life. For the sake of argument, let’s reduce expected life by a day: 3+ days.
in an effort to compete with rival companies with strong reputations, Fitbit has added more features to their devices so that they are becoming fitness wearables with smart-watch features. Of course, usage of these features take battery power.
For the following features, Fitbit has notified potential customers of significant additional battery drain:
• GPS
• Music streaming
• Always on display
But for other new features, Fitbit does not claim significant loss of battery life. if we are generous, a customer might presume a reduction of an additional day of battery life which would bring us to 2+ days.
So we started at an advertised battery life of 4-5 days. If we assume significant usage of battery life for “average use” of features not tagged as battery hogs, we are down to 2-3 days.  Let’s set that to 60 hours (2.5 days) when watch is new.
After 2 years of use - about 350 cycles - let’s assume 80% of original capacity remains.  It should take about 500 cycles but I’m trying to be forgiving to Fitbit, here.  This brings us to 2 days.
I think it’s fair to believe the battery percent gauge on the device. If it says 75% charged, I will believe it’s 75% charged of its current capacity.
Lately, my battery hasn’t been lasting very long.  I’m still under warranty (watch is 2 months old), so I called customer support and a replacement unit is on its way to me right now.
Anecdotally, I think battery drain when sleeping is less than during the day: I don’t look at the watch, the display is dim, I don’t have vibrating alerts, etc.
Even in its compromised state, I was astounded after taking most of the additional measure you recommended, that my 90% battery lasted 6 hours last night. No vibrating alarm this morning. No sleep measure beyond 6 hours.
My watch was deliberately purchased directly from Fitbit.  Until a week or two ago, the watch had been operating as advertised.
Below I’ve listed some possible causes and follow-up questions about how to manage the specific problem if it’s the cause:
• the battery suddenly became damaged. How did this happen? What can I do to make sure the battery doesn’t become more damaged until my replacement arrives.  What can I do to make sure the replacement battery stays healthy?
• the watch was defective prior to shipping. Why?  Was it a random dud? Refurbished but sold as new? A known problem in the manufacturing?  What assurances (aside from my warranty) do I have that this problem will not repeat?
• the “percentage charged” number is not accurate, so 90% could actually = 10%.  What can I reasonably expect from a replacement watch?  Why would replacement watch not have this same problem?
• what am I missing?
Apple makes a smart watch that is also a fitness tracker. Apple advertises 18 hours of battery life from a full charge assuming average use (plenty of notifications, etc.). With a new watch fully charged, anecdotal reports suggest heavy/power users get about 16 hours of battery life; average users get about 20-40 hours of life and, with conservative use a user can milk about 2 days of battery life from a full charge.
One can get a brand new Apple Watch, series 3, for about the same as a Versa 2. A 40mm Series 6, at MSRP is a little more than the MSRP of the Fitbit Sense.
While Apple products tend to be more expensive, warranties tend to be more generous and, when the device is treated as advised, Apple devices appear to last longer than their counterparts. For this reason, most of my tech is within the Apple ecosystem. Until 1 month ago, my daily computer was a 13.3 inch 2010 MacBook Pro.  It needed a repair once while under warranty.  My iPhone is 3.5 years old. Aside from battery replacement, I’ve used the warranty once for a problem I didn’t even know I had (Apple caught the problem and replaced the phone within the hour).  My iPad recently turned 6 or 7 years old. I am starting to shop for a replacement that will last another 6-7 years.
If this problem persists after additional replacement units, I may request a full refund and simply purchase an Apple Watch.
At your earliest convenience please provide the following:
(1) Reasonable (not copy and paste) answers to my above questions.
(2) A reasonable argument for why I should stay with Fitbit instead of switching to Apple.
My physical and mental health are important to me as they are to most Fitbit users. Wearables have provided incredible tools to aid is in becoming and staying healthier than without them.  I have considered Fitbit devices to be focused on fitness first, then additional “smart features.”  My wearables have only been Fitbit devices. I am currently wearing my fourth model in 6 years.
Please advise.
If you cannot, please pass this open letter to someone who can offer constructive advice.
If necessary, I can be reached directly through the contact info associated with my username (obviously, I’m not an actual Muppet).
As this is an open letter written on a moderated forum open to others who use Fitbit products, I invite constructive advice from the community writ large, as well.
Thank you.
ps. If I have edited letter, it is for typos and clarity. Primary content is the same.
pps. Some small part of this letter may have been changed by the forum posting system. I will review and make necessary changes.
Dear MochaShakespear
I am in the same boat as you. I had Garmin before this and the watch was still working excellent. The only reason I upgraded to a Fitbit was that the Garmin app no longer works for my phone. My old Garmin was only 79 dollars when I got it. It wasn't an advanced type just simple. I am getting very close to going back to it. I bought the Sense two months ago...one month later the thing completely died would not charge or turn back on. Yet only two hours before it had a full battery and was working. I never got it wet even though it stated you could. I never used all the bells and whistles...I got it for ECG...so I could send reports to my doctor due to my Lupus problems. I was grateful when Walmart took it back even though it was a day past the return policy.
I then bought the Versa 2 which I am now begging to worry will pull the same thing. In fact, today when I took it off it was a full battery or 97%...I didn't wear it because I didn't work out like I do most mornings. When I went to work out this evening the battery was at 57%.. I do not use notifications or other bells and whistles. It's primary my workout watch and my sleep monitor.  I am hearing from a lot of people during this pandemic that have bought their watches during this time having issues like mine with all the watches.  It seems Fitbit quality has gone downhill during the pandemic and I would like to know why. When I bought the Sense I spent 300 bucks...I finally went back to the negative reviews on Walmart and there were many who complained of the same thing. Some said it happened right after they charged it the first time or a month or two months later.  Now I am hearing the same thing about the Versa 2. This makes me mad and unhappy. I am about to once again return it.
