04-25-2018
10:46
15:14
AlessFitbit
04-25-2018
10:46
15:14
AlessFitbit
I just got my versa a week or two ago, the battery ran out during a 12 hour work shift, so I popped it on the charger when I got home (it had been working perfectly before this). Screen has not woken up since. That was days ago now. Its like its just dead. I have plugged the charger in to multiple places, my phone is charging beautifully from the same sources. Who do I call/where do I send my Versa to get a replacement?
Moderator edit: title for clarity
01-16-2020 16:18
01-16-2020 16:18
Awesome!!! Thank you thank you thank you!!!
01-18-2020 17:53
01-18-2020 17:53
I got my husband a Versa Lite for Christmas. It was dead on arrival, so he plugged it in and it wouldn't charge. He contacted Fitbit and they sent him a replacement. Great, it was fully charged and he wore it for 5 days. Today the battery died so he put it on the charger and NOTHING. It's the charger, I'm sure. The Fitbit worked perfectly for him all week at work, but he can't charge it no matter where he plugs it in. I'm giving it 30 more minutes then I guess I'll have to call customer service. So disappointed. I've used Fitbit for years and never had any issues until now.
01-21-2020 22:36
01-21-2020 22:36
Wish I knew about this with my other versa instead of wasting the money for a second one! I had the same issue with both, found this when it happened to my second one, and it worked like a charm after!
01-22-2020 08:44 - last edited on 02-09-2020 16:16 by LiliyaFitbit
My Versa is brand new and came fully charged. It’s my second one. I love it. But...I’ve tried everything on the forums, even bought a new Fitbit brand charger. No luck. I can’t restart it because once the “0%” shows, it goes off right away. Any help you can give will surely be appreciated. Thanks!
01-22-2020 13:47
01-22-2020 13:47
01-23-2020 13:21
01-23-2020 13:21
01-24-2020 03:56 - last edited on 02-06-2020 16:31 by LiliyaFitbit
Did you try to press down on all three buttons until it starts up again?
Then it should charge up.
01-25-2020 00:04
01-25-2020 00:04
01-26-2020 03:52
01-26-2020 03:52
Thank you!!!
01-27-2020 08:36
01-27-2020 08:36
It took mine about 10 seconds of holding all three buttons down. I was afraid it would completely reset and go back to the original settings, but it did not.
01-27-2020 08:49
01-27-2020 08:49
Thanks so much, I was about to give up before I saw this.
01-27-2020 14:23 - last edited on 02-06-2020 16:32 by LiliyaFitbit
Did it fix the problem,though?
01-27-2020 14:33
01-27-2020 14:33
Yes. It fixed the problem. I have had Versa for a year. First time I didn't charge it after low battery warning.
01-27-2020 16:49
01-27-2020 16:49
Thank you! By holding all buttons it worked. I am grateful for the information.
01-27-2020 21:47
01-27-2020 21:47
01-28-2020 09:54 - last edited on 02-06-2020 16:31 by LiliyaFitbit
I had that same scenario. Glad it's fixed.
01-28-2020 11:39
01-28-2020 11:39
Austin....thank you so much! I pushed all the buttons down and waited...sure enough I saw the Fitbit logo and now it is charging no problem!
01-28-2020 11:40
01-28-2020 11:40
About 5 seconds
01-31-2020 08:57
01-31-2020 08:57
02-02-2020 02:13
02-02-2020 02:13
I just did this and held them all together for like 10 seconds and the little Fitbit logo appeared!
