04-25-2018
10:46
15:14
AlessFitbit
04-25-2018
10:46
15:14
AlessFitbit
I just got my versa a week or two ago, the battery ran out during a 12 hour work shift, so I popped it on the charger when I got home (it had been working perfectly before this). Screen has not woken up since. That was days ago now. Its like its just dead. I have plugged the charger in to multiple places, my phone is charging beautifully from the same sources. Who do I call/where do I send my Versa to get a replacement?
Moderator edit: title for clarity
06-09-2018 07:15
06-09-2018 07:15
Best Answer06-10-2018 23:33 - last edited on 02-06-2020 16:30 by LiliyaFitbit
Hello, I can't reload my Versa. The battery is at 0% and when I put in the computer, nothing happens. The watch was plugged in my computer all the night. I do the same witch an electric plug. Nothing happens too.
Thanks for your help.
Best Answer06-11-2018 04:23
06-11-2018 04:23
Hello, I just bought my Fitbit versa today. I synced it and the battery started to run out. I decided to charge it, but it's not charging! It always says that there is not enough power to charge it, and I don't know what to do. I tried all the possible things that could be wrong and none of the tips worked. I'm very frustrated and I've tried charging it from my computers USB and with a plug. Nothing has worked 😞
Best Answer06-11-2018 05:53
06-11-2018 05:53
That is sad. Probably best to return it to fhe store you bought it from and either swap it for a nother one.
Helen | Western Australia
06-11-2018
07:19
09:54
06-11-2018
07:19
09:54
It's great to see you around @Nicofa.
If you are having issues charging your watch, I recommend taking a look at the help article Why isn't my battery charging? and follow the instructions provided there.
Let me know the outcome. ![]()
Best Answer06-14-2018 08:47
06-14-2018 08:47
Hello,
I have attempted all of the troubleshooting tips and unfortunately I have not had any luck in recovering my Versa charging capabilities. From what I understand, Fitbit is one of the most successful companies in this type of exercise technology and from my first experience being with the Versa I have been very impressed. It makes me sad to say though, I have had my Versa for 3 weeks and now there is a malfunction with this product. I hope there is some sort of solution you can provide with my Fitbit product.
Thank you,
Username: cjpereyra
06-19-2018 19:34
06-19-2018 19:34
Me too 😕
Best Answer06-28-2018 04:10
06-28-2018 04:10
What did they suggest??
Best Answer06-28-2018 10:35
06-28-2018 10:35
Hello Maggie,
After speaking to customer service over the phone, a series of troubleshooting was conducted and the solution was determined. A new charger was sent to me and it was only a matter of a few business days. I was satisfied with the rush delivery so I was able to use my Versa again soon after with no charge. My watch is back to charging as normal and has been so for the past week.
Cjpereyra
07-11-2018
19:17
06:45
AlejandraFitbit
07-11-2018
19:17
06:45
AlejandraFitbit
Versa no battery, can't work and can't use. How can I do?
Best Answer07-11-2018 20:29
07-11-2018 20:29
Have you charged your battery? Try restarting the Versa several times and then try charging again and see if it comes on. If it doesnt you may have to return it tonthe store you bought it or contact support (link in my signature )
07-12-2018
06:46
09:56
07-12-2018
06:46
09:56
It's great to have you here @nwl1997 and @NellyG thanks for the input.
I would like to know if the instructions provided by our friend worked? If you keep having issues, I recommend taking a look at the help article Why isn't my battery charging? and follow the instructions provide there.
Hope to hear from you soon. ![]()
07-15-2018 16:12
07-15-2018 16:12
The Versa is having issues of Charging. Its always shows 0% Battery Charging on display but its not getting the charge, I tried to change the Plugs and connect with the PC, Still similar issue found, Kindly let me know how to Fix this issue!
07-16-2018 07:02
07-16-2018 07:02
Best Answer08-19-2018 14:25
08-19-2018 14:25
Could you please tell me how you restarted your versa? I have the same problem where my versa is completely dead. It's been like that for 2 days and had no issues charging prior to that. I bought 2 extra chargers thinking the problem was there, unfortunately, i still have no luck 😞 I love my versa and would be very sad if it stays like that. I had the charge 2 before and had the same problem. It is still dead today :(. Please kindly help!
-Caro
08-20-2018 05:49
08-20-2018 05:49
Best Answer08-21-2018 21:00
08-21-2018 21:00
08-30-2018 14:57
08-30-2018 14:57
any updates regarding this issue i have the same thing
Best Answer09-01-2018 01:38
09-01-2018 01:38
I bought my Versa two weeks ago. Everything worked fine for two weeks Went to charge it and this time it will not charge! It’s been at 0% for 3 days and I’ve tried many things and gotten on a couple of forums. Nothings worked.
Best Answer09-01-2018 08:15
09-01-2018 08:15
