04-25-2018
10:46
15:14
AlessFitbit
04-25-2018
10:46
15:14
AlessFitbit
I just got my versa a week or two ago, the battery ran out during a 12 hour work shift, so I popped it on the charger when I got home (it had been working perfectly before this). Screen has not woken up since. That was days ago now. Its like its just dead. I have plugged the charger in to multiple places, my phone is charging beautifully from the same sources. Who do I call/where do I send my Versa to get a replacement?
Moderator edit: title for clarity
01-02-2020 06:50
01-02-2020 06:50
My Versa will not charge either. I've tried ALL suggestions. I was traveling and battery died. Surely, Fitbit must realize batteries are going to die sometime and design a device that is not so finicky. I found this device to be sub-par, poor design. I already had my Versa replaced because it continued to loose time. Customers should not have to spend so much time on purchases. I expect better quality and will not buy Fitbit again.
01-02-2020 09:15
01-02-2020 09:15
I have a Versa 2 which is as pathetic as all that came before it. It only has 1 button. Is there a fix for it when the battery is dead and won’t charge
Best Answer01-06-2020 03:33
01-06-2020 03:33
@AustinFarus25 :works for me thanks 🙂
Best Answer01-06-2020 07:54
01-06-2020 07:54
Tried this and it seems to be working. Versa is currently charging. Thanks for the insight!
Best Answer01-08-2020 13:43
01-08-2020 13:43
Thanks ! For the solution to my dead charger&versa ! Was worried id have to do without it indefinitly.😞Relief 😊
Best Answer01-12-2020 05:18
01-12-2020 05:18
Oh my god, thx so much! This worked perfectly and guess what, when the screen turned back on, the battery was at full charge, how about that. Fitbit should really fix their software.
Best Answer01-13-2020 00:14
01-13-2020 00:14
It took me about 5-10 seconds and the logo finally popped on and I set my Versa on the charger and it started charging.
Best Answer01-13-2020 00:37
01-13-2020 00:37
@AmyVersa - I have also tried the instructions in the "why isn't my battery charging" article and my watch is still dead. I have cleaned it and tried to reset it, but it does absolutely nothing. Could you please help?
Best Answer01-13-2020 05:29
01-13-2020 05:29
Try this: Hold all 3 buttons at the same time until the logo appears and then set it on the charger
Best Answer01-13-2020 05:31
01-13-2020 05:31
Have you fixed yet?
Best Answer01-13-2020 05:37
01-13-2020 05:37
If your versa 2 has only one button hold that one until the logo appears let us know if it works
Best Answer01-13-2020 05:38
01-13-2020 05:38
Hold the 3 buttons until the logo appears
Best Answer01-13-2020 09:08 - last edited on 02-06-2020 16:32 by LiliyaFitbit
I tried that it doesn’t do anything
Regards
Best Answer01-13-2020 09:09 - last edited on 02-06-2020 16:33 by LiliyaFitbit
No, it is still very much dead
Regards
Best Answer01-13-2020 09:13
01-13-2020 09:13
Thank you sooooo much, gutted, thought it had died on me. So relieved. Thank you 👍🏻
Best Answer01-13-2020 09:15
01-13-2020 09:15
I had to hold all 3 buttons for a while before logo came on
Best Answer01-13-2020 09:31
01-13-2020 09:31
No, it’s still dead. Held all three buttons for a long time. Nothing.
Best Answer01-13-2020 19:14
01-13-2020 19:14
Also worked right away. Thank you!
Best Answer01-16-2020 02:06
01-16-2020 02:06
Worked for me. Thank you!!!
Best Answer01-16-2020 02:29
01-16-2020 02:29
