Anyone having issues? It hasn't synched since yesterday and I've just done a run with Strava but no details are being uploaded and error when synching. Restarted devices and blue tooth. Any issues ongoing Fitbit?
Hi @FancyTatts Sorry to hear your morning is starting out with a tech issue. After you restarted where you able to sync? I have found it can sometime take restarting 2-3 times to get everything back to syncing correctly. If that still doesn't work, I'd suggest a full shutdown. Go to setting, scroll to the bottom, tap About, scroll to the bottom, tap Shutdown. Hopefully that does the trip for you. Good luck!
