09-23-2018
07:48
10:31
AlejandraFitbit
09-23-2018
07:48
10:31
AlejandraFitbit
Does the Versa have the same bright green screen at night like the Charge 2?
Best Answer09-23-2018 08:39
09-23-2018 08:39
The screen is not as bright and can be controlled by choosing different clock faces. Some are brighter than others.
10:32
07:42
09-24-2018
10:32
07:42
It's great to see you around @freccle and @SunsetRunner thanks for stopping by.
Keep in mind that you can always adjust your watch's brightness, you can select "Auto". Just swipe to setting and select the option you prefer.
Let me know the outcome. ![]()
Best Answer09-19-2019 05:57
09-19-2019 05:57
My Versa's display is set to Auto but at night, the display is always blindingly bright. Is there a way to fix this?
