05-28-2018
09:48
07:34
AlejandraFitbit
05-28-2018
09:48
07:34
AlejandraFitbit
I am unable to turn up the brightness on my Fitbit Versa. It is that low I can't see the clock to swipe up and navigate. Only had it since last week and its been stuck like this for a few days, how annoying! Can anyone recommend anything? I've got it linked to my phone and I can't seem to work out a way to get the screen to show. Tried in diff kinds of light too.
12-13-2019 09:38
12-13-2019 09:38
The Brightness setting on the Fitbit Versa watch is not settable. It is stuck on DIM. Screen timeout and sleep mode are adjustable. Do Not Disturb and Screen Wake are also not adjustable. All other settings are adjustable. What do I need to do so the Brightness Setting is adjustable. The screen is too dim to view in daylight.
12-14-2019 12:08
12-14-2019 12:08
I’m having the same problem. I’ve had the Versa lite for 3 weeks and I swipe to settings and a the brightness stays on dim no matter how many times I tap
12-14-2019 12:10
12-14-2019 12:10
Turning off sleep mode worked! Thank you. Now brightness is working!
12-16-2019 09:30
12-16-2019 09:30
Does not work. Tried multiple times today. Other ideas??
12-16-2019 09:31
12-16-2019 09:31
Does not work. Tried multiple times today. Battery is about 65% charged. Other options?
12-27-2019 15:16
12-27-2019 15:16
Take you Fitbit off sleep mode then you can adjust the brightness.
12-27-2019 16:30
12-27-2019 16:30
01-01-2020 12:28
01-01-2020 12:28
Many Thanks, I must have inadvertently turned sleep mode on !!!
01-09-2020 20:19
01-09-2020 20:19
I tried going through settings, but the brightness option feels greyed out and won’t switch from dim.
01-10-2020 04:03
01-10-2020 04:03
01-10-2020 07:31
01-10-2020 07:31
02-09-2020 12:54
02-09-2020 12:54
This did it!!!! The sleep mode was the trick!!!! Thank you!!!!!
02-15-2020 17:25
02-15-2020 17:25
That worked thank you so much
03-10-2020 12:39
03-10-2020 12:39
It did not allow me to tap on it, it’s on DIM and I can’t change it :(.
03-10-2020 19:26
03-10-2020 19:26
03-10-2020 20:50
03-10-2020 20:50
03-11-2020 03:32
03-11-2020 03:32
03-11-2020 04:47
03-11-2020 04:47
03-11-2020 07:33
03-11-2020 07:33
03-11-2020 14:22
03-11-2020 14:22
This happened to me too. I finally found that I had turned sleep mode on. Below screen time out is a sleep Mode option try turning it to off then checking to see if you can change the brightness level.
