05-28-2018
09:48
07:34
AlejandraFitbit
05-28-2018
09:48
07:34
AlejandraFitbit
I am unable to turn up the brightness on my Fitbit Versa. It is that low I can't see the clock to swipe up and navigate. Only had it since last week and its been stuck like this for a few days, how annoying! Can anyone recommend anything? I've got it linked to my phone and I can't seem to work out a way to get the screen to show. Tried in diff kinds of light too.
03-11-2020 16:53
03-11-2020 16:53
04-02-2020 23:33
04-02-2020 23:33
I am having same problem! ... Only had watch for 6 mos. ....
04-03-2020 07:46
04-03-2020 07:46
04-05-2020 16:36
04-05-2020 16:36
04-05-2020 20:29
04-05-2020 20:29
04-08-2020 11:40
04-08-2020 11:40
That did it. I turned off the sleep mode and was able to adjust the brightness. Thanks so much!
04-23-2020 13:55
04-23-2020 13:55
Thank you, I had the same problem and this fixed it.
Sleep mode also prevents the screen from being displayed when you flick your wrist and that was also annoying ( I thought wrongly that it had something to do with the battery being low), so thanks again!
04-25-2020 06:14
04-25-2020 06:14
Thank you so much this worked for me. The Versa was useless with it stuck on dim. I must have inadvertently put it in sleep mode.
05-01-2020 14:56
05-01-2020 14:56
Can’t turn Sleep mode off. I tap sleep mode and nothing changes
05-02-2020 11:12
05-02-2020 11:12
That worked! Thank you, thank you, thank you!!
05-07-2020 09:05
05-07-2020 09:05
I know "how" to change it, but on my watch it doesn't work. It's stuck on dim. I thought others may be having the same issue. I was wondering if there was something else I could try.
05-07-2020 10:13
05-07-2020 10:13
I had the same problem. The issue was my watch was stuck on sleep mode. I turned it off and was able to adjust the brightness.
06-02-2020 18:34
06-02-2020 18:34
that worked.
06-03-2020 08:56
06-03-2020 08:56
That actually happened to me! Thanks for the help.
06-04-2020 09:46
06-04-2020 09:46
I was having trouble with my Fitbit Versa not allowing me to adjust the brightness. When I went to settings, brightness was grayed-out so that I could not adjust it (other settings were like that, too). This is something that had just sprung up within the last week or so. I tried a hard reboot, but once powered up again nothing had changed. As I checked my Fitbit account on my phone today I noticed there was an update ready to be installed (I don't think I'd seen that recently). I installed the update, but the brightness problem was still there. I decided I'd try a reboot again. As I pressed the button for shutdown, "Quick Settings" popped up. I hit the brightness button... had to do that a couple times I think... it worked! I'm so glad to have my settings back and functional!
06-08-2020 12:49
06-08-2020 12:49
Thank you thank you thank you!
06-11-2020 06:53
06-11-2020 06:53
My brightness went dim and I didn't change it. I've gone to settings but it grayed out and won't let me change it. I've also restarted the fitbit and that didn't work either.
06-11-2020 07:33
06-11-2020 07:33
06-11-2020 07:37
06-11-2020 07:37
06-23-2020 02:16
06-23-2020 02:16
So much yes! Thank you! I couldn’t see a thing when I was outside! THANK YOU!!!!
