05-28-2018
09:48
07:34
AlejandraFitbit
05-28-2018
09:48
07:34
AlejandraFitbit
I am unable to turn up the brightness on my Fitbit Versa. It is that low I can't see the clock to swipe up and navigate. Only had it since last week and its been stuck like this for a few days, how annoying! Can anyone recommend anything? I've got it linked to my phone and I can't seem to work out a way to get the screen to show. Tried in diff kinds of light too.
06-23-2020 08:21 - last edited on 07-01-2020 21:04 by LiliyaFitbit
Once I restarted my fitbit it took a few minutes but then I was able to change the "dim". Try restarting your fitbit.
Moderator edit: format
06-23-2020 12:05
06-23-2020 12:05
06-24-2020 14:41
06-24-2020 14:41
When I go to brightness in the settings it is set to Dim and doesn’t allow me to access other brightness settings. Any other tricks to allow me to access?
07-01-2020 11:58
07-01-2020 11:58
07-01-2020 13:00
07-01-2020 13:00
07-01-2020 14:11
07-01-2020 14:11
07-01-2020 16:38 - last edited on 07-01-2020 21:05 by LiliyaFitbit
YES! Someone was kind enough (not from fitbit) to explain. There is a
sleep setting. If you switch that off, you can control the brightness!
Good luck!
[image: Image result for live love laugh]
07-01-2020 19:59
07-01-2020 19:59
07-15-2020 12:55
07-15-2020 12:55
Yep that worked. Thank you.
07-15-2020 14:48 - last edited on 08-20-2020 20:14 by LiliyaFitbit
Fantastic!
07-20-2020 11:03
07-20-2020 11:03
Thanks for posting this it fixed my problem.
07-20-2020 11:11
07-20-2020 11:11
08-10-2020 11:04
08-10-2020 11:04
1. "Brightness" choice in watch "Settings" too dim or,
2. Turn off "Sleep Mode".
08-10-2020 11:05
08-10-2020 11:05
or turn off sleep mode...
08-10-2020 11:05
08-10-2020 11:05
or it's on sleep mode....
08-15-2020 20:46
08-15-2020 20:46
HI, thank you so much for the advice. I was really think it was time for a new fitbit but after following your advice I have a working smartwatch again.
pb
08-20-2020 13:51
08-20-2020 13:51
I tap but it doesn't Change the brightness from dim. I can Chand the screen timeout though.
08-20-2020 14:15 - edited 08-20-2020 14:48
Try turning off the sleep mode on the drop down screen from your main watch screen.
1. Swipe down from your main watch screen to access 'quick settings'.
2. Press the slider switches icon, top right,
3. of the four icons, press the crescent moon/sleep mode icon, top right, to toggle on/off.
This is a seperate setting and overrides the 'dim settings' in the watches main settings page referenced above.
Namaste 🙏
08-20-2020 14:17 - last edited on 11-15-2020 19:17 by LiliyaFitbit
Thank you. I got it. I appreciate your feedback. Have an awesome 😎 day!!
Sent from Yahoo Mail for iPhone
08-22-2020 06:38
08-22-2020 06:38
Unfortunately, the Brightness selection is disabled (dimmed) and stuck on "Dim" such that I am unable to change it. The bottom line is that my Versa readings are so dim that I cannot read it. I understand that we need to conserve power so that the battery life can be extended. Unfortunately I cannot trade off inability to read the versa for battery life. If I cannot read the display of the Versa then there is no point wearing it. Therefore I am willing to sacrifice some battery life in exchange for being able to see the readings. How do I enable Brightness?
