10-27-2018
07:50
05:09
AlejandraFitbit
10-27-2018
07:50
05:09
AlejandraFitbit
All of my buttons have quit working. The first step I find in other posts is to restart the Versa, which I don't know how to do without buttons. I have tried cleaning around the buttons, they all seem clean and like they are depressing perfectly well. Just not doing anything 😞
10-28-2018
05:09
06:05
10-28-2018
05:09
06:05
It's great to see you around @tamimats.
Thanks for troubleshooting this by yourself. If your watch's buttons aren't working, you may be able to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
Let me know the outcome.
