Versa came with a little tool/item
I was so excited to put on my new Versa, I overlooked and almost threw out a little tool that came in the box. So be careful!I guess it for changing the bands.I guess it for changing the bands.
6 REPLIES 6
Thanks for the info! Haven't gotten mine yet. I can see how it could be overlooked. Whats it used for?
Community Council Member
Wendy | CA | Moto G6 Android
It's the pin that attaches the band to the device. It looks very similar to the pins the Blaze uses.
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
Thanks @N8teGee
OMG- I did overlook it - maybe that will simplify changing bands!
I don't think this is a tool. This is the pin itself and probably from the second included band.
No tools needed for band replacement.
Hello everyone! As @N8teGee explained the item you see is actually a pin for the wristband. These pins can be removed from the band (if you change wristbands or use a different size you keep using the same pin just change the band you want to wear). I have taken some pictures to better illustrate these for anyone who may have not yet received their Versa or would like to know more about this:
Sorry about the lighting (you can tell I am no photographer Robot LOL ).
Hope this helps clear some doubts and make sure you don't lose the pin!
I'll be around!
Alvaro | Community Moderator
