Versa can't connect to WhatsApp
I've just switches to a new phone.
On setting up my versa again.. I can't find the option to connect to my phone ( android) for calls or whattsapp?
It worked perfectly on my old phone
4 REPLIES 4
If you go to YouTube it will show you how to!
go to the part where it says notifications on your phone in your Fitbit app. Pleas on there and scroll down and turn WhatsApp on
Welcome to the Community, @TrueGem and thanks @millie12 for the input 😀.
As @millie12 mentioned, to enable the notifications on your watch please open the Fitbit app and tap on your profile's photo > Versa > Notifications and from there you can select which notifications you want to receive on your watch.
See you around.
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
I've tried this... whattsapp doesn't even come up ad an option?Sent from my Galaxy
Hi @TrueGem.
Thanks for the update. You should see WhatsApp when you tap on the App Notifications' option where you'll find all the apps installed on your phone and from there you can choose which apps you want to receive notifications from.
Hope this helps.
