07-24-2018
11:54
08:33
AlejandraFitbit
07-24-2018
11:54
08:33
AlejandraFitbit
I try to pair WiFi from my computer to Versa, it didn't work. I go to check the watch and go to the setting menu. I found that "IP address WiFi off". How to open it? Thanks in adv.
07-24-2018 17:02
07-24-2018 17:02
Hello, @deangang. The Versa's WiFi is setup through your phone. It will turn off when not in use to save battery.
你好,@ deangang。 Versa的WiFi通过手机设置。 不使用时会关闭以节省电池电量。
你好、@ディアンガ。それはWiFiの通話手机设定。电子电気。
Sent in part with Google Translate to make the Forums more user friendly.
07-25-2018 08:34
07-25-2018 08:34
It's great to see you here @deangang and @supersmart01234 thanks for stopping by.
I appreciate all the efforts in trying to fix this WiFi issue and would like to know if you keep experiencing it? If you do, I recommend taking a look at the help article Why won't my Fitbit watch connect to Wi-Fi? and follow the instructions provide there.
Let me know the outcome.
