08-24-2018 22:30
08-24-2018 22:30
Dear FitBit,
I have been such a fan of your products and I love my new Versa but the band-changing situation! What the actual??!! It is SO hard to change the band that I seriously wish I hadn't done $50 on the pretty woven one, and now my FitBit is locked from all the jostling and I can't get it to unlock! It has been literally an hour since I sat down to change my band and go for a workout. Needless to say, the only thing that has been exercised is my patience. Seriously. I am so annoyed right now.
08-25-2018 03:20
08-25-2018 03:20
I DO agree it is not the easiest band change Fitbit has used and I seem to press buttons everwhere when strugging with it. I have solved the problem by not changing bands lol. But that does mean I dont get to use my lovely woven one which is very comfortable to wear.
Helen | Western Australia
08-25-2018 09:13
08-25-2018 09:13
@Hexebart wrote:Dear FitBit,
The first few times I messed up my nails but now that I have the hang of it, it’s not so bad. I change bands almost daily. Make sure you hold the band at an angle when attaching the pin. There are some really helpful videos on YouTube, good luck!
08-25-2018 09:31
08-25-2018 09:31
@evilneoprincess - like you, I’ve found the trick is to hold the band at a 45 degree angle. But as @NellyG says, this is not the easiest band to change.
05-28-2020 00:19
05-28-2020 00:19
It's the worse design ever. To pay so much for the product, you should be able to change the band easily. I've got my woven band off, now cant out a band on. Now cant wear product and have been trying for over half an hour. Wont buy another fitbit!
