04-30-2018
16:42
17:06
EdsonFitbit
04-30-2018
16:42
17:06
EdsonFitbit
With initial setup I chose a clock face and changed settings to show steps. Looking at the watch it showed calories instead. I changed settings and chose calories, saved the change, then changed it again to steps and for a few minutes it correctly showed steps on the watch but it keeps reverting to calories. How do i fix this without having to keep changing settings?
Moderator edit: added label
04-30-2018 17:55
04-30-2018 17:55
Your tracker has to be synced before ANY changes will take effect.
Best Answer04-30-2018 19:17
04-30-2018 19:17
Best Answer05-01-2018 07:13
05-01-2018 07:13
If you have made the changes and synced properly and that is still happening, I would suspect the clock face is the culprit and you can contact the developer by clicking on "Contact Developer" at the bottom of your "My Clock" setting.
Best Answer05-01-2018 16:37
05-01-2018 16:37
Same here on the True Elegance watch face 😞
