11-07-2019 05:10
11-07-2019 05:10
In my experience the Versa is extremely picky about which Bluetooth headphones it will work with reliably (e.g. it can't control the volume of the OG AirPods, and two other Bluetooth sets I've tried stutter terribly when paired to the Versa).
So I'm interested to hear if anyone has tried pairing their Versa with the new AirPods Pro? Can the volume be controlled or is it always maxed out?
To be clear - I'm talking about pairing the Versa directly to the AirPods so that I playback music from the watch without taking my phone with me.
11-09-2019 11:37
11-09-2019 11:37
The connection works fine. Similar to the previous model I had to reset and repair. Only problem I have now is the volume control. Unlike the older model I cant get it to work even after resetting and repairing numerous times.
11-14-2019 10:40
11-14-2019 10:40
I have the same problem with the volume control. Other then that the AirPods work. I’m looking for a way to turn down the volume
11-20-2019 07:55
11-20-2019 07:55
I took a chance and picked up a pair of Apple AirPods Pro. As others mentioned, I found that they pair with the Versa and playback fine, but the volume controls do not work.
The level is what I would describe as "moderate", so it's a better situation than the original Apple AirPods for which the Versa played back at maximum volume.
Still, it would be good if FitBit could address this - volume controls on all my other devices (phone, TV) work fine with the AirPods, so it seems to be a limitation/bug in the Versa.
07-23-2020 17:33
07-23-2020 17:33
I am so upset that the air pod pros do not work with the Versa. I have to have my eardrums blown out if I want to use my playlist and not take my phone. Well, what's the point of having a playlist saved on a phone if we can't adjust the volume???
