10-19-2018 05:20
10-19-2018 05:20
In order to sync the two apps I am asked to login to MyFitnessPal. When I try to do it I receive this:
Best Answer10-19-2018 07:32
10-19-2018 07:32
The two sites should link. What you need to do is log in to your MFP account and then go to their apps page and find the Fitbit app. Click on that and it will walk you through the linking process. In effect it wants your permission to link up to your Fitbit account so you will need to give it your Fitbit login information.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
10-19-2018 07:45
10-19-2018 07:45
Best Answer10-19-2018 10:52 - edited 11-20-2018 06:45
If the message sent is connected to the email already exists, you probably are choosing the create account option and not the log in option.
10-19-2018 11:33
10-19-2018 11:33
