01-22-2019 19:05
01-22-2019 19:05
Aside from some static and the earbuds not being able to sync with one another and the versa, it will usually only play out of the receiver earbud.
I have tried restarting and repairing my watch with headphones but only one earbud still works. Both work fine on my iPhone
Would like some info on this.
 Best Answer01-23-2019 21:29 - edited 01-23-2019 21:58
@Mimicampbellf Editing my previous post. It seems your earbuds connect using the hands-free profile. It could happen if Versa did not support A2DP. Sorry I couldn't be more helpful.
02-10-2019 19:04
02-10-2019 19:04
What is A2DP? What are other reputable ear bud brands that will work seamlessly. I don't want to use the fitbit flyers as the have a neck strap.
 Best Answer02-10-2019 20:35
                              02-10-2019 20:35
@Mimicampbellf You can read more on Bluetooth profiles here. Just to make sure, after you paired your JBL with Versa, have you tried pressing both JBL buttons on both earbuds at the same time for 3 seconds to force the connection?
