08-21-2019 07:40
08-21-2019 07:40
I have had my Versa for about a year now, and have had no issues until this past week. Normally I get about 3-4 days wear on the battery before I need to charge again.
Last week my versa started power cycling itself repeatedly, I would get an occasional error message that read "Clock error" and directed me to log into the Fitibit App to fix this. Then the watch would restart again. It did this so many times that it drained the battery completely. I would fully charge it, and it would be dead within a few hours.
It seems to work fine while its on the charger. I'm not getting errors or power cycling while its charging, only when its off charger being worn.
I've tried to do a reset, I've upgraded firmware and re-installed the app on my phone, reset the Bluetooth connection. Nothing seems to help.
08-22-2019 06:08
08-22-2019 06:08
@DoctorDonna welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the battery is not lasting as long as a should. By the way, thank you for troubleshooting this issue before contacting our forums. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. These steps are helpful in order to improve the battery life of your Versa.
Keep me posted on the outcome! ![]()
Best Answer08-22-2019 06:08
08-22-2019 06:08
Best Answer08-23-2019 07:40
08-23-2019 07:40
Hello,
This is not an issue of just having a battery that doesnt last as long as Id like. The watch does back-to-back power cycles all day until the battery dies. I cannot keep it charged, and none of the functions of the device work while the device is restarting. I need a better solution than what youve suggested.
08-23-2019 07:56 - edited 08-23-2019 16:22
I faced the same issue and it was resolved after I restarted my versa.
Update :
My Versa is dead now 😭😭😭
Best Answer08-23-2019 08:07
08-23-2019 08:07
I have already manually restarted my versa several times. It hasnt helped
Best Answer08-23-2019 16:23
08-23-2019 16:23
