12-18-2018 12:04
12-18-2018 12:04
Ever since I got the iPhone app update (v 2.84), my Versa has been counting ghost steps while charging. For example, I woke up this morning to see a notification on my iPhone that read, "Only 354 more steps to go!" This happened the last time I charged my Versa, and has not happened since. What's going on?
Best Answer12-28-2018 05:15
12-28-2018 05:15
Hi,
Changing the clock face didn't work for me, but the 3.0 update did.
Best Answer12-18-2018 12:27
12-18-2018 12:27
Hi, did you already try to reboot your Versa? Press and hold the left and right lower buttons intill the Fitbit logo appears on your Versa and release the buttons. Sometimes you have to do this more than once. See if this solves your "ghost steps" problem.
Best Answer12-18-2018 12:36
12-18-2018 12:36
Thanks for your reply. Yeah, I've rebooted my Versa quite a few times, actually, hoping that it would clear the bug out. No luck yet.
Best Answer12-18-2018 12:42
12-18-2018 12:42
Hi, sounds like a strange question to you, but what the name of the Clock Face you're using?
Best Answer12-18-2018 13:06
12-18-2018 13:06
I think it's called Layers. I've never changed my clock face, so it's the standard, I guess, straight from the FitBit factory.
Best Answer12-18-2018 13:09
12-18-2018 13:09
Hi, did you perform the update to version .30?
Best Answer12-18-2018 13:30
12-18-2018 13:30
Best Answer12-18-2018 13:33 - edited 12-18-2018 13:34
The only solution I can think of now, is to change your clock to another face and after that reinstall the Layers again. Reboot your watch after that and see if that solves your problem. Good luck.
12-28-2018 05:15
Hi,
