01-01-2019 16:56
01-01-2019 16:56
I received a Fitbit Versa for a Christmas present and I thought it was great.
However, two issues I'm currently having are:
Firstly;each morning I've woken up with thousands of steps done (when I've been asleep) this is been a combination of wearing it during the night, and it being on the side, both on a bed side table with other electrical devices and fans, and in another room with absolutely no devices or vibrations near it.
and Secondly; I can do a walk whilst counting the actual steps I'm doing, and the Versa is recording a large amount more. For example, I measured a 30 step walk at home, and the Versa counted it is 91........
Is this a hardware issue? Is this a Software issue? If a software issue, when will it be fixed?
01-01-2019 17:03
01-01-2019 17:03
My husband and I are having the problem with steps being counted while sleeping.
I don't see a reply from fitbit tech people on this.
01-01-2019 18:32
01-01-2019 18:32
@Soli1234I suggest you contact customer service, and be persuasive. It is called abnormal ghoststeps while not doing anything. You should get a replacement.
01-02-2019 15:22
01-02-2019 15:22
It's just from vibrations. No need for a replacement. Mine used to do this if I forget and put it down by my bedroom fan at night. Since the latest update though it stopped doing this even if it's exposed to vibrations.
01-02-2019 16:10
01-02-2019 16:10
@Soli1234writes : "and in another room with absolutely no devices or vibrations near it."
@anmanwarwrites: "It's just from vibrations."
Go figure! I stick with my earlier reply. Other ppl have reported large amounts of ghoststeps doing absolutely nothing with no evidence whatsoever of vibrations. This includes 1000's of ghoststeps during charging. Rest assured: it is not common at all, but there are ppl/trackers out there that have this, and is annoying. I still suggest to contact customer service, and yes they will try to tell you it is vibrations, and yes thus you have to be persuasive 🙂
