03-11-2019
05:30
10:10
03-11-2019
05:30
10:10
My Versa suddenly went to logo screen and won’t do anything. I have tried restarting it multiple times and even factory reset. I have deleted the app wiped all data etc etc like it was a brand new device and it still just stays on the logo screen apart from when syncing from the app I do get the passcode come up but once entered then it just returns to the fitbit logo.
03-11-2019 06:18
03-11-2019 06:18
03-11-2019 06:18
Contact Customer Support.
03-11-2019 06:20
03-11-2019 06:20
Hi @MrsMason2016 I have flagged your post for a moderators assistance.
Helen | Western Australia
03-11-2019 10:22
03-11-2019 10:22
Welcome to the Fitbit Community @MrsMason2016! Thanks for taking the time to troubleshoot this issue with your Versa's display. Nice way to go!
I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps.
Thanks for all your help guys @NellyG and @SunsetRunner!
I'll be around, keep me posted!
05-24-2019 21:33
05-24-2019 21:33
I have the same problem. The logo won’t disappear.
07-23-2019 10:53
07-23-2019 10:53
I have the same issue. It happened after I forgot to charge it and it ran out of battery. Recharged and then this.
With my issue the logo doesn't go away, it is permanently on the screen (so assume my battery will die soon).
Can't do anything with it.
Please help!
Ross
07-23-2019 14:23
07-23-2019 14:23
Welcome to the Community Forums @RossMcG! Thanks for the details provided.
Please try to restart your Versa by following the steps below:
Give this a go and let me know if the Fitbit logo disappears. I'll be around, keep me posted.
07-23-2019 23:43
07-23-2019 23:43
07-25-2019 10:58
07-25-2019 10:58
Hi @RossMcG! Thanks for following the tips and recommendations I've provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
08-22-2019 11:52
08-22-2019 11:52
Hello, I’ve tried all the steps and a my Fitbit Versa only shows the logo on the screen. So far, all I’ve been able to do is get it to go away and make it come back. Can’t find it on Bluetooth either. Help would be greatly appreciated!
08-22-2019 14:03
08-22-2019 14:03
Welcome to the Community Forums @AllenMou. I'd recommend to restart your Versa by following the steps below:
Give this a go and let me know the outcome, I'll be around and glad to further assist you.
09-02-2019 02:19
09-02-2019 02:19
This is not a solution...
09-02-2019 10:27
09-02-2019 10:27
Hello there @SouthAfrican, thanks for stopping by. If your Fitbit is stuck at the logo screen, please follow the recommendation I've shared here.
Let me know the outcome, I'll be around.
09-03-2019 08:02
09-03-2019 08:02
Only the logo and a back red light will come on my Versa. I have tried numerous times to go to factory settings and to update; the green check box will come on but it continues with the logo only and red light on the back.
09-03-2019 08:29
09-03-2019 08:29
Происходит то же самое. Одно лого ,если с синхронизируется ,то только на пару секунд и обрывает. Перезагружал кнопками назад и вниз. До заводских настроек сделал. Теперь вообще не могу пользоваться часами. Буду благодарен если вы решите мою проблему.
10-07-2019 09:14
10-07-2019 09:14
People are saying they have tried all these steps and you are cutting and pasting some steps they already tried AND a step that involves their FitBit working which they already communicated does not work. It is fairly difficult to get into your phone Settings when your phone is locked up.
It appears this is not an isolated problem and likely not fixable without sending your FitBit in for a new one (a pain to do) or return it to Costco or whatever store you got it from if you have a warranty.
10-10-2019 15:22
10-10-2019 15:22
My husband just had the same issue two days ago. Already went through the steps as noted from others with the same problem. Very frustrating. We're thinking of going to Apple. I have a Versa less than a year old that won't hold a charge for more than a day.
10-10-2019
15:29
06:09
JuanJoFitbit
10-10-2019
15:29
06:09
JuanJoFitbit
You can always try holding down all 3 buttons and reset it, all apps will be saved 👍
Sorry just seen you have tried that
Moderator edit: merged reply
10-10-2019 18:28
10-10-2019 18:28
Same issue and still stuck... 😞
10-10-2019 21:23
10-10-2019 21:23
