03-11-2019 05:30 - last edited on 03-11-2019 10:10 by MarreFitbit
My Versa suddenly went to logo screen and won’t do anything. I have tried restarting it multiple times and even factory reset. I have deleted the app wiped all data etc etc like it was a brand new device and it still just stays on the logo screen apart from when syncing from the app I do get the passcode come up but once entered then it just returns to the fitbit logo.
04-26-2020 23:34
04-26-2020 23:34
How did you fix this problem? My fitbit is doing exactly the same and I can't seem to restart my fitbit. Please help?
04-27-2020 03:15 - last edited on 06-19-2020 18:35 by LiliyaFitbit
Call customer service.
Sent from iPhone
05-05-2020 10:01
05-05-2020 10:01
I have this same issue. My fit bit versa is stuck on the logo screen and nothing I do will fix it. I have tried all of the solutions below but nothing is working.
05-27-2020 06:22
05-27-2020 06:22
Got mine a few months ago and now it's stuck on logo screen as well. Grr.
05-27-2020 10:24
05-27-2020 10:24
Hi everyone! due to the recent events, I apologize for the delayed response. However, thank you for participating in our Fitbit Community.
I'd like to follow up and help you with your Fitbit watches since they are stuck on the Fitbit logo.
Please try a factory reset. To do so on your device, follow the steps below:
Finally, make sure that they're fully charged and see if the issue gets fixed.
Keep me posted on the outcome.
06-06-2020 13:25
06-06-2020 13:25
My Fitbit Versa is STUCK at the Logo screen. I have tried everything that everyone said and it's still STUCK at the Logo screen.
06-08-2020 06:20
06-08-2020 06:20
Mine has done this since i've owned it.
I've had to deal with support 6 times over it and the 5 times before this after a few weeks of leaving my fitbit out of battery on the bedside table the holding down buttons reset worked and it would come backtolife, this time nothing works and the logo is on the screen all the time part from when battery dies and then it show 0% charge it and logo again, the app can't find it and i've not been able to use it for over 3 weeks. I've spent 3 hours on the phone, 4 hours in chat and have 46 emails back and forth with the support team over last 3 weeks..... finally they all agree that its defective and always had been so I can have a replacement if I post it to them (i'm in UK they are in Netherlands ) this'll cost me £15 to post which i'm meant to pay for, i refused and eventually they sent me a free post label. On reading on here how long it takes to get new one or that some don't get them I contacted them again and refused to post. Eventually they sent me link claim a replacement or 50% off a new device. i'm going to see if replacement arrives if not i'm taking this further as in UK its under warranty for 2 years so they need to fix it then i'm buying an apple watch. i've had fitbits since the start but after their shocking customer service i'm not buying another. My advice out of all this is don't give up just keep at them on all platforms. its hard work and very tiresome which is what they want I reckon and they hope we all give up and then it goes out of warranty. They eventually listen sometimes
06-08-2020 09:52
06-08-2020 09:52
Same issue with my wife's Versa 2.
Their support is useless. Device is bricked because of the firmware upgrade and i have been waiting ages just to hear from them.
Never again.
iwatch it is...
06-14-2020 06:20
06-14-2020 06:20
I'm having exact same issue as Ross, plesse help!
Fitbit logo just flashes on screen. Occasionally, after restart and app ready will sync but then goes right back to flashing logo (like a traffic caution light).
I've tried the restart and factory reset but can't even get it to factory reset to happen.
What else can be done??
06-14-2020 07:14
06-14-2020 07:14
06-14-2020 08:12
06-14-2020 08:12
I've tried. Still flashing logo and randomly shows "data not cleared. Sync Try again"
Now what?? Any other suggestions?
06-14-2020 08:43
06-14-2020 08:43
I had this issue at 13:30pm just as I went out for a 10k walk! I tried to reinstall the watch to the app while walking by it took 1.5 hours. It finished when i got home. The click faces wouldn't synchronise and my data did not show on the phone e.g. sleep, exercise days etc. I decided to check Google play and see if an update was required and it was for the app. Now everything is working fine.
06-14-2020 09:13
06-14-2020 09:13
My Fitbit Versa is back working. I left it on the charger for over 3 days, I went back to check it out (BOOM!!💣) It was working. I don't know if it was an update that fix it or a ghost 👻( Lol) . I just know it's back working... Good luck to you.
06-15-2020 12:18
06-15-2020 12:18
I tried a few times this, still doesn't work
06-16-2020 12:55
06-16-2020 12:55
So this issue started with me today. I've restarted per your directions multiple times. I cannot take the additional step to rurn it off because the device won't go beyond the logo screen.
06-16-2020 12:56
06-16-2020 12:56
Seriously? Turn it off? If one could get it to where you see the settings, we wouldn't have an issue!
06-16-2020 13:05
06-16-2020 13:05
Mine did the exact same thing and then finally went blank and won't restart.
Because it is out of warranty I was offered a 25% discount on a new one. It seems more could be done since this appears to be a wide spread problem that mostly occurred this past weekend.
06-16-2020 14:30
06-16-2020 14:30
06-16-2020 19:19
06-16-2020 19:19
I realized that the app updated the same day my Fitbit started having issues. It seems I've finally gotten it to factory reset after many attempts (after uninstalling and reinstalling the app) and adding a new device through the app, seriously took about 5 tries. Now it shows the clock face but the screen doesn't recognize touch, notifications don't come through and still will occasionally flash the Fitbit logo. My versa is less than 2 years old! This seems way to common for them not to address!! Maybe it's a bug in the app but that doesn't explain the issue with the screen not acknowledging tap/touch. Any one able to reach out from Fitbit Customer Service??
06-17-2020 07:18
