03-11-2019
05:30
10:10
03-11-2019
05:30
10:10
My Versa suddenly went to logo screen and won’t do anything. I have tried restarting it multiple times and even factory reset. I have deleted the app wiped all data etc etc like it was a brand new device and it still just stays on the logo screen apart from when syncing from the app I do get the passcode come up but once entered then it just returns to the fitbit logo.
10-21-2019
08:15
06:05
JuanJoFitbit
10-21-2019
08:15
06:05
JuanJoFitbit
I also have exactly the same problem. I tried to restart and have also tried a factory reset by pressing all 3 buttons. Nothing is getting rid of the logo. Eventually all the power ran out so I recharged but I still just get the logo. Please help!!
Any progress Dtesnow? I'm also stuck!
Moderator edit: merged reply
10-21-2019 21:17
10-21-2019 21:17
10-22-2019
04:27
06:05
JuanJoFitbit
10-22-2019
04:27
06:05
JuanJoFitbit
I have tried for over a week now and I am getting the same thing. Nothing further than the Fitbit screen and its frozen.
the Fitbit Versa only has one button,where do you see other buttons?
10-22-2019 04:29
10-22-2019 04:29
10-22-2019 11:53
10-22-2019 11:53
10-23-2019
04:11
06:06
JuanJoFitbit
10-23-2019
04:11
06:06
JuanJoFitbit
Sorry to hear you were only offered 25% discount - not a good solution.
Momma Bear there's a button on the left and 2 on the right!
10-23-2019 10:35
10-23-2019 10:35
I’m having the same problem with my versa and nothing you suggested is working. I’ve only had my fitbit since August and it already doesn’t work? What a waste of money. This is extremely frustrating
10-23-2019
19:39
06:08
JuanJoFitbit
10-23-2019
19:39
06:08
JuanJoFitbit
This was all tried multiple times with no luck. Fitbit has nothing to say about this known issue. Just sad, their support is crap.
There is one on the left and 2 on the right
Sent from my iPhone
10-31-2019 12:43
10-31-2019 12:43
Dear Maria,
I’m facing the same challenge. My Fitbit is stuck at logo screen. Tried using every possible solution put up on this forum but doesn’t help. Request you to raise a ticket for the same.
Thanks,
10-31-2019 13:43
10-31-2019 13:43
Best Answer11-03-2019 02:24
11-03-2019 02:24
Facing the same problem.
Best Answer11-12-2019 17:32
11-12-2019 17:32
I have the same issue. No attempts have worked.
11-12-2019 17:42
11-12-2019 17:42
Hello, I am experiencing the same issue. I have chatted with someone and no luck. I have tried to set start over but cannot be found on my bluetooth.
Best Answer12-12-2019 09:31 - edited 12-12-2019 09:38
hi
i tried to update software in my fit bit versa screen freez try to re boot not working fit bit logo on screen
past 2 hours tried everything hold back button and release
everything but still not working
12-12-2019 18:19
12-12-2019 18:19
My Versa 2 had the logo stuck on the screen as well and my issue was an update that I had not downloaded in the Fitbit app setup process. So check for updates if you are having this issue.
01-06-2020 08:20
01-06-2020 08:20
The fix suggested (hold back button and bottom button) isn’t working and I can’t turn the device off as it is stuck on the Fitbit logo. Do you have any other suggestions?
Best Answer01-06-2020 08:21
01-06-2020 08:21
Tried this and it doesn’t work
Best Answer01-06-2020 09:32
01-06-2020 09:32
01-11-2020 13:02
01-11-2020 13:02
My one month old unit went to logo screen versa 2. Tried all suggestions also did a live chat with Fitbit which was useless.totally frustrated
01-14-2020 06:30
01-14-2020 06:30
