01-26-2019
14:13
12:17
DavideFitbit
01-26-2019
14:13
12:17
DavideFitbit
My display only comes up after taping the screen a few times. How do I set it so it comes on when I turn my wrist to check it? Isn’t there an auto setting?
01-26-2019 14:34
01-26-2019 14:34
Hi, press and hold your left button for about two secs and the activity screen shows. This shows whether your screen is automatically activated or manually by pressing the left button. If it's not turned on to automatically, press it and it will change from manually to automatically. After that your screen should go on when you move your wrist.
