Versa displays a "lost connection" message
Message says lost connection. Connect in the Fitbit app that does not work either. How do I get this reconnected ? There is no reset like my other that had NO issue ever. Versa 2 has issues all the time.
lost connection won't sync since 5/18. Whats up? No new updates available. Indicates lost connection but will not connect just has ( ! ) re-install does not fix the issue.
3 REPLIES 3
Hi @Vktoria, welcome to our Fitbit Community!
I'm sorry to hear that your Versa 2 is not connecting to your phone. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
  • Release the button briefly (for less than 2 seconds).
  • Hold the button again until they feel a second, longer vibration, which indicates they initiated the factory reset.
  • Set up your watch from scratch as advised in this help article
Finally, monitor your Versa 2 and see if the connection issues get fixed.
Keep me posted on the outcome.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Thanks I did do that and lost all my personal settings which did not make me happy. However on my computer the tracker can not be found ànd I un-installed the program deleted the fitbit, reinstalled and it still does not find the tracker.
The tracker on my computer still does not work. I did an Uninstall and reinstall and that did not work either.
