04-12-2020
03:26
05:48
JuanJoFitbit
04-12-2020
03:26
05:48
JuanJoFitbit
Hallo.
Today, when i started looking to some new displays for my Fitbit Versa the fitbit app said that there's an update I needed to install in order to install new displays or even be able to download some new apps to my watch. I managed to update the fitbit app but I could not update my fitbit Versa because there was no such option as 'update' or 'there is an update available' as usual.
So I thought I should factory reset my watch. After doing so, the watch now says 'Data not cleared, Sync & try again.'. I tried to sync through my phone but it just didn't work. I have done so many things such as unpairing the watch with bluetooth, forse restart, I even deleted the watch from my app and now I can't pair it again. My phone does not find my watch and my watch only shows the fitbit logo after pressing the left and bottom button and then it says 'data not cleared, Sync and try again'.
Someone please help! Nothing seems to work!
Moderator edit: format
04-27-2020 05:47
04-27-2020 05:47
Hi @cimbom1, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
I would like to follow up with your Fitbit Versa since it displays a "Data not cleared" message and would like to know if the issue persists or if it got resolved. By the way, thank you for troubleshooting this issue before contacting our forums.
In the meantime, let me know if the factory reset was performed as described below:
Looking forward to your response.
04-27-2020 05:56
04-27-2020 05:56
Um... Where are those buttons? My Versa only has one button on the side...
05-03-2020 20:48
05-03-2020 20:48
I have the same problem with my Versa. Twice I have tried the three-button factory reset, and every time it still gives me the initial log, but then the "Data not cleared, Sync & Try Again error message.'
