Versa does not hold the connection to wifi
Recently bought an fitbit versa.
Only problem I have is that the versa does not hold the wifi connection so i can’t update and load music using the wifi connection.
i can configure a wifi connection on the versa and this connection is visible. The next moment the wifi connection is displayed but does not function. In the list of wifi networks that are available, the connected wifi is als named with better signal receiving. You can connect again with this wifi network, but the same result. It won,t function.
i tried to get a solution of fitbit support but the only thing they advise are the standard actions ( reset, install the app again, try pc in stead of mobile phone, etc). I did that all but no positiv result.
I think something is wrong with the wifi part of the versa, but had someone else the same problem and a solution ?
1 REPLY 1
@Theome welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't stay connected to your WiFi.
I was able to get in touch with our Support team and was told that they sent you an email recently. Please check out your email account in order to proceed accordingly.
I'll be around if any question arises.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
