Versa doesn’t even respond to charging
Tried to update my info on my phone because I went for a jog this morning. It only picked up the second run and not the first half an hour. I tried to sync but it did not pick up the first run at all. Tried to restart the device and now it won’t switch on. Doesn’t even respond to charging
5 REPLIES 5
Same here. Versa worked yesterday and today I can’t get it to charge or turn on...
the same happened to me this morning. I put it in the charger and it is just black, no charging, nothing.
This happened to me twice, once 7 months into using one i bought; then again 7 months into using the replacement they gave me. Now I'm **ahem** out of luck and no longer interested in purchasing a new fitbit product
Happened to me three weeks ago. Tried everything. Was online with Customer Service for 45 minutes trying to fix it.  Ended up sending me out a replacement (but noting mine was under warranty).
This happened to me just now. Won't turn back on. I clicked restart on the fitbit as per procedure as it wouldn't connect to my home Wi-Fi just kept saying "Wi-Fi off" on my watch. Now won't respond at all. This is a replacement watch after the last ones screen died. I have it on charge and the screen is just black no response even when the screen is double tapped.
