04-24-2018
19:37
10:07
LanuzaFitbit
04-24-2018
19:37
10:07
LanuzaFitbit
I've tried few different calendar apps and all of them sync ok with my google calendar (and show the list of events on my fitbit), but non of them show the appointment notification on Versa. I've tried everything, restarting phone, bluetooth and fitbit, refreshing, read all fitbit suggestions for that problem, still nothing. My calendar events appear within the app, but when the appointment time comes, notification only shows on the phone, nothing pops up Versa. Txt and call notifications work perfectly, but this calendar thing drives me insane. Anyone else had that problem?
Best Answer04-28-2018 17:39
04-28-2018 17:39
I'm having the same problem. Nothing works and I've tried everything you have tried.
Best Answer05-02-2018 20:23
05-02-2018 20:23
I' having the same issue 😞
Best Answer05-07-2018 10:03
05-07-2018 10:03
FitBit support has been on it since I posted it. But they didn't come up with anything... I did a bunch of resets, including the factory one, and still nothing. I'm glad that other notifications work, since calendar is not my #1 need, but the fact that it doesn't work drives me insane.
05-27-2018 09:46
05-27-2018 09:46
What apps show the schedule on your fit bit? My calendar appts come up on the versa, but 1 at a time. I would like to be able to scroll through the day as I could on the Gearfit pro
Best Answer01-02-2020 10:14
01-02-2020 10:14
hi, was a fix ever found for this issue, I see this post is now over a year old.
It would be great to know how to get this working!
Best Answer01-09-2020 13:24
01-09-2020 13:24
I was having this problem. I got mine to work. I found a site where the lady said to go into your settings on your phone to your notifications..she said make sure fitbit is selected or turned on and also your calendar app your using. I did this..went to my calendar... set an event for a few minutes latter it just came through. Hope this works for you too!
Best Answer01-09-2020 13:28
01-09-2020 13:28
https://community.fitbit.com/t5/Charge-2/Calendar-Notifications-Charge-2/td-p/1912906 This is the link where i found the answer..The Moderators name is Marrefitbit.
Best Answer01-10-2020 11:00
01-10-2020 11:00
Appreciate your help, i did this but it's didn't work for me.
I reached out to the moderator for help.
thanks!
L.
Best Answer01-20-2020 02:55
01-20-2020 02:55
I’m having the exact same problem and still after looking and trying all of the suggested fixes, still get No calendar notifications on my Fitbit Versa2 (along with no text message notifications either)! 😡
