04-30-2019
04:31
06:13
MarcoGFitbit
04-30-2019
04:31
06:13
MarcoGFitbit
I have had the same setting on my versa for a while now and just 2 days ago noticed that my Fitbit won't hold a charge anymore. I put it on last night before I went to bed at 100% battery. This morning it was at 22% and dropping quickly. I have never had a problem before and I have already tried some troubleshooting with no success.
04-30-2019 17:55
04-30-2019 17:55
Hi, which troubleshootings have you already done? Restarting it 4-6 times in a row by pressing and holding the left and right lower buttons untill you see each time the Fitbit logo and release the buttons, etc.
04-30-2019 23:25
04-30-2019 23:25
Try a total watch reset, helps.
05-01-2019 01:36
05-01-2019 01:36
Hello everyone,
This fix worked really well for me. I’m really happy.
Thank you so much.
05-01-2019 03:30
05-01-2019 03:30
This started happening to my versa yesterday as well. Its worked perfectly for month and now its.....😡
05-01-2019 12:35
05-01-2019 12:35
This fix didn't help. I did it a couple times and I did a complete reset. Any other suggestions?
05-01-2019 15:16
05-01-2019 15:16
Hi. I used Kuzibri’s suggestion (few posts up). I reset my Fitbit 6 times in a row and it sorted it straight away. My battery drain is now averaging less than 1% per hour. So I should get back to 4/5 days usage again.
05-01-2019 16:05
05-01-2019 16:05
05-01-2019 16:09 - edited 05-01-2019 16:12
Hi, what he meant was that restarting multiple times did the job for him, so no FR each time, just restarting your Versa multiple (4-6) times in a row. It's absolutely mandatory to do this multiple times cause that will reset the internal system of the Versa.
05-01-2019 16:47
05-01-2019 16:47
Mine started the same thing about three days ago.. Was working great, last 5+ days of working and or working out but just started after I did a factory reset and it required a firmware update, ever since then it's Dead by noon. What could possibly be wrong?
05-01-2019 16:52
05-01-2019 16:52
Hi, after a FR you will need to setup your device all over again to your phone cause it's basically a new device after the FR (in the box state). See if this guide is helpful for you to get your Versa up and running again.
05-01-2019 17:05
05-01-2019 17:05
05-01-2019 17:09 - edited 05-01-2019 17:14
Hi, now it's time to contact Customer Support with the specific mention that you already did the "restart procedure" without any luck. Whenever they ask if you also did a Factory Reset, just say yes, cause in earlier post in this topic this has been mentioned also and did not work.
05-04-2019 01:27
05-04-2019 01:27
I did a factory reset and it seems to have sorted it out (fingers crossed)
05-07-2019 06:23
05-07-2019 06:23
Hello @Ckrakow12, @Jake01 and @AKSHales thanks for joining the Fitbit Community. It's great to see you too @Jacko64, @Robert38117, @SunsetRunner, and @Kenzibit, I hope you're doing well.
First of all, I would like to apologize for the delay in the response. @Jacko64, @Jake01 thanks for letting us know you're issue has now been resolved, thanks for letting us know.
@Ckrakow12 and @Robert38117 I reached out our Support Team in your behalf and it seems you have already have created cases with them and that you have reached a satisfactory resolution.
@AKSHales, tell me, have you performed a factory reset on your Fitbit Versa or have you just restart it normally by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen? Knowing this will be very helpful for us to check this further.
Thanks for your patience and understanding, have a great day.
