06-15-2020 12:02
06-15-2020 12:02
I downloaded the latest firmware update for my Versa and now it wont hold a charge for more than 20 hours. I tried factory resetting and turning settings off and it STILL dies in less than 24 hours. This is really annoying as I can't go to sleep with it on without having to remember to charge it first.
06-15-2020 12:27
06-15-2020 12:27
Same. Mine used to last 5 days easily, after update it wont hold a charge for 9 hours. Disabled everything making it essentially the DUMBEST and most expensive "smart" watch ever and it still doesn't last more than 10 hours. This is my 4th Fitbit watch and will be my last if they don't fix this issue. From what I've seen so far they don't acknowledge any issue and simply infer you aren't charging properly and tell you to disable all features.
