09-13-2019
15:58
13:07
DavideFitbit
09-13-2019
15:58
13:07
DavideFitbit
My Versa is not even a year old and the edges of the screen are fading, the left side of the screen doesn't register touching it, so I cannot change the alarms on it, among other things. I have to use the side buttons to bring up workout options and to turn it off. The battery is needing charged every other day. It's super frustrating that something so expensive wouldn't even last a year. I'm gonna need to replace it soon. Has anyone else experienced this?
09-13-2019 16:12
09-13-2019 16:12
Hi, if you search this community you will find a lot of posts/topics withj the same problem. Try resetting your Versa a few times and if that does not solve your problem, contact Customer Support. They will glad to help you. Regards kuzibri.
