09-05-2018
09:50
04:56
AlejandraFitbit
09-05-2018
09:50
04:56
AlejandraFitbit
For a second time my Fitbit drops my steps for the day to under 10 or 0 and makes my active minutes
1445. I have reset it and synced and uninstalled app and nothing helps. It happened from July 13th - July 25th (only noticed going back as it has changed). And now since Sunday it is changing every day, I have the jiff app that takes my steps from Fitbit so I can see what they were. Please help! My Versa was purchased in May.
05:05
07:43
09-06-2018
05:05
07:43
It's great to see you around @miraberes.
Thanks for troubleshooting this by yourself. I would like to know if you are manually logging any type of activity that might be taking away your steps and adding active minutes? If so, I recommend deleting those activities and see if your information goes back to normal. Or you can also provide me with some screenshots.
Let me know the outcome. ![]()
Best Answer09-06-2018 05:56
09-06-2018 05:56
Thanks for your reply... working with support now ...
09-06-2018
06:00
07:42
09-06-2018
06:00
07:42
Thanks for the information @miraberes. I hope you get this solved and if there is anything we can help you with, do not hesitate to post it.
Keep the stepping up!
