11-08-2020
10:08
11:24
RicardoFitbit
11-08-2020
10:08
11:24
RicardoFitbit
Hello, my versa keeps freezing, will randomly get stuck on the shortcuts screen, buttons won’t work. I have reset it about 4 times today, it’s always fine for a little bit after I reset it but then it starts freezing again.
11-09-2020
11:24
04:59
11-09-2020
11:24
04:59
Hi @Clarebear91, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. Since the restart process didn't completely fix this situation, I recommend you to follow the next steps to perform a factory reset on your Versa:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Let me know if further assistance is needed and if you have any additional questions.
Best Answer11-10-2020 10:11 - edited 11-10-2020 10:24
Hello,
i have done the reset that you suggested and now I can’t get my Fitbit to connect to the app
many thanks
Clare
Update
Its currently doing the set up thanks 🙂
11-10-2020
16:01
05:15
11-10-2020
16:01
05:15
Your reply is appreciated @Clarebear91.
Thanks for your update and for taking into consideration the troubleshooting steps that were shared on my previous post, I'm happy to know that the setup issue was resolved. Please do not hesitate to contact me back if you still need assistance with your Versa, I'll be here ready to help you.
Thanks for being part of the Fitbit family!
Best Answer11-11-2020 01:33
11-11-2020 01:33
Hello,
sorry to bother you again but the left hand button is not working still. The top and bottom right buttons are very slow. Is there anything else I can do?
many thanks
clare
