10-11-2019
23:12
04:17
YojanaFitbit
10-11-2019
23:12
04:17
YojanaFitbit
My versa has frozen on a screen saying 'short cut Press and hold button to access preset shortcuts'
I have tried to turn it off using back and bottom left button but it won't turn off. Could my back button be broken?
This happened after I updated .....
Thanks
10-12-2019 02:43
10-12-2019 02:43
Hi @Jrij
Contact support for advice & guidance: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
10-12-2019 10:32
10-12-2019 10:32
10-24-2019 17:32
10-24-2019 17:32
Hey have you got a fix? I’m experiencing the same issue after I upgrade my versa last night.
10-24-2019 17:36
10-24-2019 17:36
I fixed. Just scroll down and you can find a save button at bottom. Click save it. Then it can work.
05-28-2021 09:18
05-28-2021 09:18
Same thing happened to my versa today. I called customer service but was not able to help.. it’s still frozen. This happens after I updated it.. and then they said it’s out of warranty. This is so sad.
06-19-2023 04:24
06-19-2023 04:24
What happened at the end? I’m trying to fix mine. It does not seem possible. Is it?
