Versa glass is lifting
I wear my watch every day and just noticed that the glass is lifting off the watch itself. I've only had it less than a year, is there a way to fix it, or so I have to get a new one?
7 REPLIES 7
@KrisDC I am afraid there's no easy fix beside taping it and putting it in a case. You can get one from Amazon. You can try reaching out to Customer Support but I am afraid this type of damage is not covered under the standard warranty. Please contact CS anyways, perhaps they will be able to advise. Good luck.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
Thanks -- I'm on a roll with hitting the gym and don't want/need any hiccups -- including my watch to fall apart. I appreciate the advice.
Hey @KrisDC, it's great to see you around and @Marrrmaduke thanks for the input.
I am sorry to hear about what is happening with your watch's display. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
Let me know if you need anything else. Robot wink
Yes, they are extremely quick in responding and I'm appreciating all the help. Hopefully, this will be an easy fix.
Hi there! I'm having the same issue with my screen lifting. What was the outcome from customer service?
Thank you!
HI,
Sorry for the delay. When I reached out to them it was determined my warranty was still good, so they replaced the watch itself. Definitely worth going to them directly.
Hello,
I appreciate your reply. My versa warranty is expired but I will still reach out to customer support.
Thank you,
