08-02-2019 13:56
08-02-2019 13:56
I bought the Versa about 3 weeks ago. The green led light has stopped blinking and it is no longer tracking hear beat or sleep. I have tried restarting, factory reset a number of times. But it is still not working.
08-04-2019 07:39
08-04-2019 07:39
Hi @Toomanyshoes thanks for joining us. It's great to see your participation in the forums @Kay_dk! @NellyG that was of great help, thanks!
I really appreciate all the time you've taken to try those steps @Kay_dk. Since those steps didn't solve the issue you're having, I've requested to our support team to create a case on your behalf. You should soon receive an email from customer support.
@Toomanyshoes Can you please confirm if you've followed the suggested steps? I'll be glad to keep assisting you.
I'll be around.
Best Answer08-02-2019 15:04
08-02-2019 15:04
I'm having the same issues. At first the heart rate monitor wasn't working and I reset it several times, still not working. Now today I noticed it's not tracking my steps at all.
08-02-2019 18:34
08-02-2019 18:34
Hi @Kay_dk Go to the settings app on the Versa and check that the Heart Rate is turned on. If it is and is not working please come back here.
@Toomanyshoes Try restarting the Versa several times and see if that fixes it.
Helen | Western Australia
08-04-2019 05:23
08-04-2019 05:23
Have tried turning it on and off. Nothing is working.
Best Answer08-04-2019 05:52
08-04-2019 05:52
@Kay_dk I have flagged a moderator to come and help you
Best Answer08-04-2019 07:39
08-04-2019 07:39
I'll be around.
Best Answer08-04-2019 10:17
08-04-2019 10:17
05-17-2020 11:15
05-17-2020 11:15
I have done all of the above and my Versa is not resetting or tracking my HR
06-07-2020 02:36
06-07-2020 02:36
Hello. I have been having the same issue, the green LED light on my watch stopped working, it's not blinking anymore. I restarted my watch 3 times and nothing. It says the heart rate is on but it doesn't read anything. I did 2 factory resets and it did not work. It was working well last week and then all of the sudden it stopped. I don't know what else to do. Thank you.
07-11-2020 18:23
07-11-2020 18:23
This question was not answered. Why is it marked as the best answer? I have the same issue and would like to get a fix - not instructions that dont work...repeatedly.
09-17-2020 18:28
09-17-2020 18:28
What do you do if factory reset and shutting down does not work? I’ve done that multiple times and now it’s not even tracking steps.
10-15-2020 11:23
10-15-2020 11:23
I'm having this same issue and I cannot find a solution anywhere. At this point I'm just ready to get an apple watch because it's so frustrating having problems with this over and over.
10-23-2020 03:03
10-23-2020 03:03
I have the same issue. I can't find an answer. Come on where can I find a sollution. I have Versa 3 one month.
I have reset 3 times and a hard reset but green light won't work!!!!
I am not satisfied that I can't find a sollution.
10-23-2020 04:11
10-23-2020 04:11
10-23-2020 10:37
10-23-2020 10:37
06-17-2021 18:37
06-17-2021 18:37
My 5th and LAST FitBit just broke (after warranty expired)…
05-21-2023 16:54
05-21-2023 16:54
This happened to me as well. Versa 2 and Charge 5. 2021, 2023. Both of them had a green light not working that caused Heart Rate not to work after 1yr mark. I personally think Fitbit company is doing this on purpose. So we keep buying their watches every year. Not cool. I'm done with them.
07-21-2023 08:51
07-21-2023 08:51
Exactly??? Customer support is awful
Best Answer07-21-2023 08:52
07-21-2023 08:52
Same issue, my Fitbit is 6 months old tried customer service chat twice zero help
