06-24-2018
12:41
17:03
EdsonFitbit
06-24-2018
12:41
17:03
EdsonFitbit
I have a new Fitbit Versa (yesterday), the device has been charged. It went down to 20% today and I charged it however after the charge I had a blank screen and the device is not responding. Any advice?
Moderator edit: added label
06-24-2018 13:18
06-25-2018 00:29
06-25-2018 00:29
Hi, tried this and it’s still blank and unresponsive.
any other tips?
06-25-2018 00:49
06-25-2018 00:49
Hi
I have the same problem. Screen black-out, and a message on Clock Face Error.
I am using the original clock face from Fitbit.
06-25-2018 07:11
06-25-2018 07:11
@MurrayMints18 wrote:Hi, tried this and it’s still blank and unresponsive.
any other tips?
Since you don't have a responsive screen, try the 3 button Factory Reset which, if successful, will return your watch to how it was when you took it out of the box. Follow the instructions below very carefully and precisely:
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely , the Fitbit logo reappears quickly and boots without factory reset.
If that doesn't do the trick, contact Customer Support.
