10-28-2019
09:14
09:33
AlvaroFitbit
10-28-2019
09:14
09:33
AlvaroFitbit
My versa hav higher hartrate under the wrist at my arm?
10-29-2019
09:41
13:47
10-29-2019
09:41
13:47
@Pelle1953 Welcome! It's great to see you around!
Let me help you with your Versa showing a higher heart rate. Remember that the device is designed to be worn with the watch face towards the outer side of your arm. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
10-29-2019 10:28
10-29-2019 10:28
Thanks. I have to try this.
