06-29-2019 18:22
06-29-2019 18:22
My new Versa screen works well at night but it is so dim during the daytime outside that it cannot be viewed at all.
The solution provided by the community suggests that on the fitbit Versa I need to swipe to settings and then scroll down to Brightness. That would work great if my fitbit had an item labeled Brightness, on the settings which it does not. Any other suggestions?
06-29-2019 18:30
06-29-2019 18:30
Sorry, I found the brightness control but it isn't located where the Community help suggested its location. I have to swipe to the left until I find the Settings for Brightness and then select the brightness choice at that location on the fitbit. I guess it is a different OS version.
