05-13-2019
22:59
16:38
DavideFitbit
05-13-2019
22:59
16:38
DavideFitbit
My Versa has stopped showing my sleep stages and is only showing my basic sleep pattern. I have done nothing different and it has done it for nearly two weeks now. I have followed all instructions for how it gets the sleep stages but it's still not working.
05-14-2019 06:46
05-14-2019 06:46
Ahh yes, then thats the problem. Is the Versa giving you Heart Rate readings on the actual watch? Is it just not recording in the app (it needs to get to the app to get sleep stages)? If it is recording and showing on the watch but not the app, then uninstall the app, reinstall it and log back in and see if HR starts recording
If you are getting no readings on your Versa, go to the settings app on your watch and check that Heart Rate is turned on. If it is already on, turn it OFF and restart the Versa several times, then go back and turn it on and see if it is now working.
Helen | Western Australia
05-14-2019 00:53
05-14-2019 00:53
Hi @frenchie11 What have you done to try and rectify the situation? Have you restarted the Versa several times? Restart your tracker
05-14-2019 02:00
05-14-2019 02:00
Best Answer05-14-2019 06:01 - edited 05-14-2019 06:02
Is the green light on the back flickering rapidly, and are you getting consistant Heart Rate recordings through the night?
Also it might be worth tryjng a Factory Reset (settings app on the watch and scroll down to About)
05-14-2019 06:17
05-14-2019 06:17
Best Answer05-14-2019 06:46
05-14-2019 06:46
