09-10-2019 17:23
09-10-2019 17:23
My Versa has worked great until recently. It stopped working in the middle of the night. It no longer tracks my heart rate, my active minutes, and my sleep because of the heart rate. I have reset it may times. Turned the heat rate feature on and off. I have also done a factory reset twice. Nothing has worked. Now where the flashing green light usually is on there is a solid red light. Please help!
09-10-2019 17:43
09-10-2019 17:43
Hi, since you have done all the possible actions to solve the problem, I would advice you to contact Customer Support ASAP. Regards kuzibri
Best Answer09-10-2019 17:44
09-10-2019 17:44
Hey,
That sounds like all the troubleshooting you can attempt for that issue. I'd suggest you to get in touch with Customer Support!
Best Answer09-14-2019 09:41
09-14-2019 09:41
Thank you for your time, and customer service did help me!
Best Answer09-14-2019 09:42
09-14-2019 09:42
Thank you for your time, and customer service did help me! Thank goodness it was still under warranty.
