Versa has stopped vibrating on goal completion
Any suggestions on how do i get the feature active again?
Moderator edit: format
1 REPLY 1
Hi @Anwesha, welcome to our Fitbit Community! I'd like to follow up and help you with your Fitbit Versa since it doesn't vibrate on goal completion.
Please try a factory reset. To do so on your device, open the Settings app > About > Factory Reset or Clear User Data. Sync your watch before this in order to avoid losing current data. Finally, monitor your watch and see if the issue gets fixed.
Keep me posted on the outcome.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
