05-01-2019
11:26
17:32
DavideFitbit
05-01-2019
11:26
17:32
DavideFitbit
Hi, I got my Versa 2 months ago and the heart rate monitor just stopped working a few days ago. I tried everything there is to try and it still isn't working. What should I do ?
05-01-2019 11:39
05-01-2019 11:39
Hi, go to the settings of your Versa and switch the HR off, restart your Versa several times and after that switch the HR on again. Did you already do that? BTW, is the green light of the HR sensor working? Otherwise, contact Customer Support about it.
05-01-2019 11:39
05-01-2019 11:39
05-01-2019 11:42
05-01-2019 11:42
Hi,
thanks for your help ! Yes I tried all of that already but it looks like the sensor is no longer working. I don't see the green light like I used too. I wrote an email to customer services but is there a phone number I can call ?
05-01-2019 11:45
05-01-2019 11:45
I tried turning the setting off and restarting the watch again and it worked ! I had to do it 4 times but it finally worked and the sensor is back on.
thanks a lot
05-01-2019 11:46 - edited 05-01-2019 11:48
Hi, the normal windows for the Support Team to answer an email is 24-48 hours. You also can send them a direct message to @FITBITSUPPORT.
EDIT: You're most welcome!!
05-05-2019 23:47
05-05-2019 23:47
I have the same problem, I try your solution (turn off and reboot, turn on and reboot). At the start the green light is turn on but after a seconds it is turn off forever, so no tracking the heat rate.
06-03-2019 22:26
06-03-2019 22:26
How do I restart my versa
05-27-2020 00:38
05-27-2020 00:38
My Heart rate also not workinhg. I tried many time and the led greenlight sensor still not working.. Any idea to check what is the problem
