04-17-2018 11:10 - last edited on 07-21-2021 19:55 by LiliyaFitbit
My new Versa is great but the heart rate monitor does not seem to work. The videos say there is a blue light but mine has not blue light in the back?
Is mine just broken, should there be a blue light HR monitor?
06-12-2020 03:46
06-12-2020 03:46
06-12-2020 03:59
06-12-2020 03:59
Thanks for replying. I've gone onto account and then pressed on versa (my device) and there is no where that says anything about heart rate! I'm so confused. I've got other family members to check it too to prove I'm not going crazy.
06-12-2020 04:24
06-12-2020 04:24
06-12-2020 07:03
06-12-2020 07:03
I found settings under 'account' and there is a section called 'heart rate zones' however this only has: custom max heart rate, custom zone and then the limits- nothing about auto or on/ off heart rate. It seems we have different apps- I have an iPhone and maybe the apps are different for android and apple?
Thanks again
06-12-2020 07:20
06-12-2020 07:20
06-18-2020 19:57
06-18-2020 19:57
I have done reset on my fitbit Versa 2 to get the heart rate monitor working, but I have to do it everyday, some times two or three times in a day. It should not be this complicated. I have only had the device since December (got it as a Christmas gift).
06-19-2020 00:02
06-19-2020 00:02
06-19-2020 12:05
06-19-2020 12:05
I got my heart rate finally to work again after resetting it 7 times. I now have to restart it about 20-30 times a day as my heart rate continuously turns off and this is the only thing that fixes it. I had my versa replaces less than a year ago so it shouldn't be this faulty. I wouldn't advise anyone to get a Fitbit as so many people seem to have issues with the heart rate ! I've just bought an Apple Watch instead- its a shame because I loved everything the Fitbit app had to offer but mine and my mothers Fitbit device has become unusable due to the heart rate not working.
06-19-2020 12:06
06-19-2020 12:06
I have no tattoos.
06-22-2020 20:51
06-22-2020 20:51
"Check the setting to make sure the HR monitoring is on," How exactly do I do this? Be specific.
07-28-2020 07:21
07-28-2020 07:21
Agreed! I have been using Fitbit for years and never had any problems until I bought the Versa.
They also changed their warranty period from what it used to be (two years) and now its only one. Of course, because they are so slow with customer service I am now just beyond the one year mark and they said they couldn't do anything else but would give me 10% off to buy a new one. Why would you want to buy a new one if there is such a prevalent issue with the HR monitor malfunctioning?
I was shocked, and will not be buying another Fitbit, which is really a bummer. Has anyone had a positive experience with the Apple watches?
07-28-2020 07:23
07-28-2020 07:23
I have the same issue, but I have the regular Versa (not a special addition one). I also do not have any tattoos, so just a general malfunction with the versa it seems like.
07-28-2020 07:27
07-28-2020 07:27
Very frustrating, and Fitbit does not seem to care! I would be doing an overhaul on my product if I knew there was this major of an issue with such a large number of devices.
Once the hear rate monitor stops working, your sleep can no longer be tracked and your workouts are no longer calculated/picked up on by the Fitbit. Essentially renders it useless, unless you only want to track your steps and know the time 😕
09-02-2020 03:14
09-02-2020 03:14
Thank you! That also worked for me! 🙂
03-17-2021 15:35
03-17-2021 15:35
My heart monitor stopped working and can’t be fixed. I communicated with Fitbit support and they offered a 35% discount toward another replacement watch. What I found out is that this has been an ongoing issue that Fitbit is aware of but doesn’t have a fix. I feel the 35% discount is not an adequate fix since this seems like a defect. Very disappointing! I’ve moved on to another brand for a sport fitness watch.
03-18-2021 08:57
03-18-2021 08:57
03-18-2021 09:09
03-18-2021 09:09
You are correct. I believe they should have if they really believe in customer service. I have an Apple Watch coming so I’m moving on. People should be aware of this defect.
Thx
S
04-27-2021 19:45
04-27-2021 19:45
Ok
Finally I will have installed a third party app
simple heart rate and it works but not near my rate so I will keep trying other apps
07-13-2021 13:50
07-13-2021 13:50
This issue is not resolved. On multiple forums the support team says RESOLVED just to report good metrics on issues. There is a bug that caused heart rate to die out after updates. And they won't admit it. I have tracked 15+ people who had this issue and all were after updates. My wife delayed updates for 6 months and was fine - until she finally updated, Then it hung up and gradually died out. No amount of resets and factory setting help. It may come on for few hours/a day then again die out.
07-13-2021 17:00
07-13-2021 17:00
