06-12-2018
19:43
07:51
AlvaroFitbit
06-12-2018
19:43
07:51
AlvaroFitbit
Hello group...received new fitbit Versa yesterday. Set-up went well however it appears that the BPM Sensor is not working properly. On my wrist it doesn’t register...the band is tight so i feel the sendor is on my skin. When i remove it from my wrist and place a finger on the sensor it will turn green intermitantly. Is anyone else experiencing this problem. I have had the “Charge” for a few years and have not experienced this problem. Any ideas?
06-04-2020 13:35
06-04-2020 13:35
Best Answer06-15-2020 02:13
06-15-2020 02:13
Hello. I tried this and my heart rate is still blank on my versa screen. I’ve reset it multiple times, also synced it and shut it down and nothing
04:01
12:03
06-15-2020
04:01
12:03
Hello I had a similar problem, in fact both my walking and heart monitors
weren't working. What I did to resolve the problem was to change my clock
face and it came back! I hope this helps.
Best Answer06-15-2020 04:52
06-15-2020 04:52
Best Answer06-15-2020 11:56
06-15-2020 11:56
Best Answer06-15-2020 12:07
06-15-2020 12:07
Hi there @Niecy17, @One-stop, and @Carla4Garda, thanks for trying to help!
Hello @LeahBarnett, welcome to the Community Forums. I appreciate you've taken the time to follow the tips and recommendations provided here to solve the issue with your heart rate. Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Best Answer06-15-2020 13:36
06-15-2020 13:36
Best Answer06-15-2020 13:45
06-15-2020 13:45
22:31
04:45
06-15-2020
22:31
04:45
Have you tried changing your clock face??
Best Answer06-16-2020 04:48
06-16-2020 04:48
Hi there @Pepacecily. Thanks for the feedback you've provided towards our product. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback. Though, I've seen you were offered a 25% discount as per our Warranty Policy. This is the best option to help you get back on track with the Fitbit family I'm sure our team will be more than glad to help you further with this. Keep in mind that every case is completely different from the other's.
Hello @LeahBarnett. Please stay tuned to your inbox, someone will reach out to you as soon as possible since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
Thanks for trying to help @One-stop!
Let me know if there's any further questions.
Best Answer06-20-2020 16:10
06-20-2020 16:10
this is my second replacement.. I had emailed the Fitbit company and mine was still under warranty and all I had to do was pay the shipping and my heart rate thing again worked fr a couple of weeks and then it stoped working 😤🙄🤦🏻:female_sign:🤬 I am very furious...I honestly don’t know what I am doing wrong? I had waited like a couple of days just recently to wait for it to die and I re started it back up just today and now the heart rate think is not working... the green light is not even showing up! 😤 I honestly don’t know what the problem is with the sensor? Everything else works with the watch it’s just the heart rate monitor thing not working? I don’t know if anyone else is having issues with the versa 2? But I love it I just wish the sensor would just freakin work 😭😣😤
06-22-2020 04:54
06-22-2020 04:54
I was wondering why this was happening, thank you. Have put on other arm.
07-30-2020 06:21
07-30-2020 06:21
I've tried all the suggested fixes listed here and my heart rate monitor still isn't reading?
Cotton swab, restart and shutdown. Nothing. Now what?
Best Answer08-18-2020 03:33
08-18-2020 03:33
Thank you for this, this actually worked for me!
Best Answer08-26-2020 18:56
08-26-2020 18:56
I have done all the things suggested & my heart rate monitor is still not working on my versa.
I have reset the watch, reset the phone, deleted & reinstalled the app. I have also turned off & on the heart rate mode on the watch as well as washed the contacts. Nothing seems to work.
I have also noticed poor battery performance in the last 5-6 months. Maybe the two things are related.
Best Answer08-27-2020 09:29
08-27-2020 09:29
Ok i had the same problem, you need to go into your Versa 2 and through the menu, where you have the cog symbol? you swipe from right to left and bring up the main menu and find the 'Settings' icon (the cog) and from there you scroll down 'Heart Rate' and select it. That should turn it on.
08-27-2020 09:38
08-27-2020 09:38
Thanks but I did that, turned off and on several times. It is now On. No change.
Best Answer08-27-2020 19:28
08-27-2020 19:28
I have also done that & it is still not working. I have a first generation Versa, not the 2.
Best Answer08-27-2020 22:45
08-27-2020 22:45
Oh that sucks, I'm sorry. Sounds like the device is broken. 😞
Best Answer09-15-2020 04:37
09-15-2020 04:37
Yes, it does suck. Now it just tracks steps. 😞
