06-12-2018
19:43
07:51
AlvaroFitbit
06-12-2018
19:43
07:51
AlvaroFitbit
Hello group...received new fitbit Versa yesterday. Set-up went well however it appears that the BPM Sensor is not working properly. On my wrist it doesn’t register...the band is tight so i feel the sendor is on my skin. When i remove it from my wrist and place a finger on the sensor it will turn green intermitantly. Is anyone else experiencing this problem. I have had the “Charge” for a few years and have not experienced this problem. Any ideas?
12-26-2019 21:52
12-26-2019 21:52
12-27-2019 06:02
12-27-2019 06:02
They have definitely heard about this issue. I was reading about it on the forum posts before mine did the same thing. They just stopped caring about their customers and don't want to take proper responsibility for a clearly defective product. I expected a $300+ product to last more than 1 year and 4 months. I ended up getting the Samsung Galaxy Active 2. The fitness tracking isn't as accurate, but at least it works, smooth scrolling from screen to screen, and I can make and receive calls right from the watch. All at the same cost as the Versa!
12-28-2019 09:09
12-28-2019 09:09
My heart rate sensor is not working properly. I tried to restart my fitbit versa and even set the sync off. Deleted the device or unpaired it from the app and the device's heart rate is still not working after it is again paired
12-29-2019 10:11 - edited 12-29-2019 10:12
Yeap same here, definitely a defective product. Mine is/was 1 year 4 months old. What a scam. Good thing I bought squaretrade warranty, hopefully they send me a check instead of another watch that WILL break.
Never buying Fitbit again.
01-07-2020 09:42
01-07-2020 09:42
After restarting my versa 2, turning the the bpm on/off on the watch several time I decided to moved it around on my skin to test the sensor and it appears that it can not be on top of a tattoo. I moved the watch to my dominant wrist and it seems to be doing fine now. Not a fan of wearing it on my dominant wrist but I suppose I will have to get used to it since that is the only place it will work properly.
If there is a solution to the tattoo issue please let me know.
01-07-2020 10:02
01-07-2020 10:02
01-15-2020 17:02
01-15-2020 17:02
If anyone has there versa lite or versa model in general on there wrist over a tattoo it will not read heart rate through a tattoo
02-11-2020 06:46
02-11-2020 06:46
I have restarted the versa multiple times and checked that the heart rate is set to on. I have resynched multiple times. Worked very well until now. The green lights either stop or only one or two go on and then they stop. Time for a new versa or is this fixable?
02-11-2020 08:19
02-11-2020 08:19
I don't know if this would help or not, but have you tried cleaning the back with a cotton swab? I was having a problem with mine not charging (I know, not the same thing) and I had wiped the back with a damp cloth, which didn't help, but using a damp cotton swab did. Maybe the device isn't registering the heart beat because of skin oils or something?
02-11-2020 09:33
02-11-2020 09:33
I've found that if you have tattoos where you're device is located it doesn't work as well.
02-11-2020 12:35
02-11-2020 12:35
02-20-2020
06:11
12:01
02-20-2020
06:11
12:01
I'm having the same issue. I noticed that the option to put the heart rate in auto mode is gone in the app, it now just says Heart Rate Zones. That might have something to do with it. Some might be affected more than others due to a software update. I tried troubleshooting it, to no avail. Not even a factory reset and enabling it in the device settings made any difference.🤔 If I find a fix, I'll share it.
Moderator edit: text color
02-20-2020 12:42
02-20-2020 12:42
02-20-2020 12:56
02-20-2020 12:56
02-20-2020 13:23
02-20-2020 13:23
02-22-2020 12:13
02-22-2020 12:13
Even after a factory reset the heart rate sensor is doing doing absolutely nothing.not at all pleased with Fitbit in the slightest . Warranty is out and y’all seriously tried to give me 25 percent off of a brand new one!
02-22-2020 16:59
02-22-2020 16:59
02-25-2020 08:28
02-25-2020 08:28
I have tried all the steps you have listed and still my heart rate isnt registering. Is there anything else I can do?
04-04-2020 14:58
04-04-2020 14:58
Hi
I got a new Fitbit versa lite yesterday and it isn’t reading bpm, I have checked all settings and they are on and to auto, I’ve done a reset but nothing seems to be working.
Help! (Please 😊)
04-07-2020
22:10
11:29
04-07-2020
22:10
11:29
Uh,oh. Looks like you have a defective one. 🙄
