Versa heart rate sensor not working
ANSWERED
i had reset my devices, charge and try whatever step as mention and refer as previous topic but my sensor light not working at all after workout. Please help?
335 REPLIES 335
I finally ditched mine for a garmin
Sent from Yahoo Mail on Android
I too was torn about getting the Apple watch. But paired with my iPhone, I
couldn’t be happier and so glad to have moved on. Good luck with whatever
you decide.
I tried all of the above steps without any success.
Same goes for me.  Tried all steps suggested without luck. Also cleaned the sensor as mentioned and no green sensor light or bpm.
Rather go for a garmin
Pls upgrade to an Apple Watch Fitbit is useless
Hello, my sensor is not working. I have tried everything mentioned above. Any other recommendations?
@jeffreyT831
my suggestion is to get an Apple Watch.
Buy yourself a garmin or apple watch Fitbit isnt going to assist u in any
way
I hear you. I’m on my third failed Fitbit device and now I’m totally done. My first device was the Charge 2 that suddenly showed a vertical crack on the screen. Upon research I learned that this was a common problem. Since it was within the 1 year warranty, Fitbit promptly replaced my device with another Charge 2. However, within the next year, this replacement had the same problem! When I spoke to customer service, they told me that they couldn’t do anything for me because the device was out of warranty. When I explained that I had the replacement for less than a year and it suffered the same issue, they said the warranty is from the date of the original device and doesn’t apply to the replacement! Ridiculous! Last year, I decided to try one last time and purchase the Versa. Turns out, this device stopped working (no heart rate monitoring and failed battery) just 2 months out of the warranty period! I tried all the fixes to no avail. Looking through the Fitbit community it appears that this is a common problem. Fitbit routinely replaces these flawed devices if they are within the warranty, but for countless other devices the company does nothing. To me, a flaw is a flaw and should be fixed. This is obviously not normal wear and tear because users are having the same issues shortly after buying the device.
I have also been offered the insulting 25% discount. I called to speak to a supervisor today, but was instead put on hold for 10 min and mysteriously disconnected (with no call back of course). Why would I buy another fitbit device with this poor track record and the fact that the company won’t truly stand behind their products?  How many times can Fitbit say things like “I’m sorry for you negative experience” or “thank you for sharing this as it will make us better” before actually doing something to increase device reliability?
Yes! I know what you mean I had some Fitbit’s that had a band issue they replaced it and the same thing happened again, I finally decided after all that to go with the Apple Watch because I have a iPhone, I’m glad now I did.I have to charge it about every night but I’m used to it now, I had a versa last, the heart rate monitor on it stop working.
I have the same problem!? No sensor no matter what I do?!? HELP.
Nooo didn’t work.
Yes! I feel your pain! Same thing happened to me. No light and this is a replacement for it and only a few months old?
i think they want you to buy more
expensive watch!
LOL!
FIX THE PROBLEM! I won’t  buy anything from
you...
Moderator edit: merged reply
I followed everyone's advice and got an Apple watch.  I am so much happier.  I also trust it will last much longer.
Just what they wanted you to do!
Sent from my iPhone
If you are out of warranty, unfortunately Fitbit will not help you at all except offer 25% off a new device that may suffer the same consequences. This is a flaw with the product and Fitbit should honor a repair/replacement.
Both heart rate and weather not working. Have turned off rebooted several times. No luck
This has been a common problem. Mine was replaced bc it was still under warranty. If not.....S.O.L. There have been so many problems with the Versa until BestBuy will not sell their extended warranty for it. That's pretty bad bc I really love my Versa. I'm holding my breath on this replacement. When it dies I'm going to transition over to the Apple watch and phone.Sent via the Samsung Galaxy Note9, an AT&T 5G Evolution capable smartphone
Garmin is better than apple watch !!
Hmmmm. I wonder why there are no FitBit representatives responding to any of these posts? If you are within the warranty, the flawed device will be replaced with the same flawed device, and warranty will expire with the original purchase. If and when you are out of warranty, you are SOL.
Exactly!Sent via the Samsung Galaxy Note9, an AT&T 5G Evolution capable smartphone
