Versa heart rate stops working
My heart rate tracker shuts off mid work out and then will start to work again the following day. Anyone else have this issue? The green light also shuts off during that time. I already had my first verse replace from not turning back on.
3 REPLIES 3
@rdolan99 It's great to see that you've visited the Fitbit Community!
Let me help you with your Versa's heart rate sensor. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Alvaro | Community Moderator
Hi! I did that and nothing changed.
I even unsynced the verse and no change.
